Manuals XA20 XA25 at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
For the Canon XA25, XA20, XA10 and all VIXIA / LEGRIA Series AVCHD camcorders.
Old May 10th, 2013, 01:33 PM   #1
Manuals XA20 XA25
Hi
Manuals for XA20 and XA25, PAL versions, are now released:
XA20
XA25
Regards,
/Bo
Bo Sundvall is offline   Reply With Quote
Old June 7th, 2013, 11:46 AM   #2
Re: Manuals XA20 XA25
One thing I have noticed in reading the manual for the XA20/25 & HF G30 & comparing them to the HF G10 is the quoted run times with the two largest size batteries they make for these cameras. Waaaay shorter than the quoted run times on the HF G10. I hope this is not the case, as it is significantly shorter than the previous model cameras. Roughly an hour less on these new models compared to the old ones.
I have an XA20 on order, so I guess I will be able to answer my concerns with real world experience in a couple of weeks or so.
Regards,
Bryce
Old June 10th, 2013, 06:23 AM   #3
The XA10 was rated at 3.2 watts power use in the spec page of the NTSC version manual.
The XA20 PAL manual lists 4.5 watts.
Expect ~30% less runtime with XA20 and the same battery compared to the XA10 under their test conditions. YMMV.
I also note the XA20 manual is a bit shorter (fewer pages).
dpalomaki@dspalomaki.com
Don Palomaki is offline   Reply
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
