With the WD-H58W, is my Tiffen UV filter superfluous?
I bought a Tiffen UV filter to go on my XA10 to protect the lens. I am going to buy the Canon WD-H58W wide angle for the camera. Does that render my Tiffen superfluous when I am using the wide angle? Is there any reason to keep it on and put the wide angle on over it? Moreover, is it possible to put a polarizer over the wide angle to protect it? From the photos it appears the answer is no.....
Re: With the WD-H58W, is my Tiffen UV filter superfluous?
Yes, you will not need or want the UV filter when using the wide lens. I don't believe the lens you are buying has filter threads, so no, I don't think you can use a filter on the lens, but I could be wrong.
I agree. If the UV is there to protect the XA10 lens, you do not need it with the WD mounted.
If you need filters with the WD (no filter threads as I understand it) consider clamp-on holders. The Cokin system with the universal ring might work (but I've not tried it).
dpalomaki@dspalomaki.com |
I've got Canon WD-H72/43 wide angle convertors on all my A1, A1S and HV20 and HV40 cameras, obviously I think they're great, I don't take them off :)
What first impressed me was the great colours through them. Those bigger lens are heavy on the front of your cam, so you'll need to re-balance it on your tripod. I have a thin strip of white adhesive tape on the lower left side of my A1/S cams and I balanced the camera with the heavy WD-H72 lens on it, on my tripod. Then I marked the corresponding position on that tape, so I can quickly set the rig up. Correct, they don't have a front thread for filters, but they could have provision for a lens hood. I've made cardboard hoods for the A1/S cams but wind can be a problem. It seems to me the front glass has a tough protective coating, but I'm always careful and use a blower brush to remove sticky airborne microgrit before I run the cleaning cloth. Always do this at home before you go outdoors, by then it's too late :( Cheers.
Drink more tap water. On admission at Sydney hospitals more than 5% of day patients are de-hydrated. Last edited by Allan Black; October 12th, 2012 at 06:29 PM. Reason: made it clearer. |
