Audio level indicator on XA10 at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
For the Canon XA25, XA20, XA10 and all VIXIA / LEGRIA Series AVCHD camcorders.
Old May 28th, 2012, 02:55 AM   #1
My newer XA10 does not show the audio levels when using the internal mic as my older XA10 does.
I've been through the menu repeatedly and cannot find a way to make this happen, any suggestions?
Old May 28th, 2012, 04:20 AM   #2
Re: Audio level indicator on XA10
This might help .. Audio level meters
Cheers.
Drink more tap water. On admission at Sydney hospitals more than 5% of day patients are de-hydrated.
Old May 28th, 2012, 06:06 AM   #3
They are talking about external mic settings, Alan. I'm talking about internal. I'll dig out my manual after I wake up, must go to bed.
Old May 30th, 2012, 12:32 PM   #4
The XA10 shows the audio level when it is switched to M but not to Auto. This may be your problem.
Giving my XA10 a workout in the Canadian Rockies at present.
Christopher Dunn is offline   Reply With Quote
Old May 30th, 2012, 12:55 PM   #5
Christopher, thanks. I was in M mode, as I white balance, etc manually at all times, but I'll try switching to auto and then back to see if it will help "kick it" on or something. thanks again!
Old May 30th, 2012, 01:05 PM   #6
I see now Chris, go to menu, AUDIO, and you can choose auto or manual gain, and also whether to have indicator on even during auto. I guess I set it up on my first cam and forgot how I did it.
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
