Do you use ND filters? at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
For the Canon XA25, XA20, XA10 and all VIXIA / LEGRIA Series AVCHD camcorders.
Old December 4th, 2011, 10:37 AM   #1
Just curious who uses ND filters, and if you've really NEEDED to use them? When I am out in the bright sunlight I pop on a CP filter and that seems to do a pretty good job and haven't used ND filters. What are you guys using?
Mark Goodsell
Mark Goodsell is offline   Reply With Quote
Old December 5th, 2011, 07:45 AM   #2
Re: Do you use ND filters?
On the XH-A1 yes. On the XA10 it is automatic after the the aperture drops to f/4.
They are important in bright light and to avoid diffraction effects caused by small apertures. Sometime they can help reduce depth of field.
dpalomaki@dspalomaki.com
Old December 6th, 2011, 01:51 AM   #3
Originally Posted by Don Palomaki View Post
...On the XA10 it is automatic after the the aperture drops to f/4.
I've never been quite clear on that.
Do the auto ND filters kick in without needing to turn on a menu item, or use any special setting?
For example: shooting @ 60i, 1/60 shutter priority, auto exposure- the ND filters will simply activate automatically as the exposure gets brighter?
Bob
Old December 6th, 2011, 09:03 AM   #4
That is my impression. In aperture priority as you adjust the aperture you will see it move to f/4 and then a series of ND settings before the aperture setting resumes from f/4 to f/5.6.
Old December 6th, 2011, 06:58 PM   #5
Terrific!!
I think that the XA 10 is absolutely one of the best designed small cams I've ever come across :)
Bob
Old December 6th, 2011, 07:13 PM   #6
One argument to an external ND filter on the XA10, which I have, is to get a shallower depth of field and still have the benefits of a stop or two less light can give. I use it to darken the background which just requires a little more light on the foreground subject.
In photography there's several effects possible with an ND Filter. Some good tutorials on youtube. Cheers
Kawika Ohumukini is offline   Reply With Quote
Old December 6th, 2011, 07:20 PM   #7
When shooting around aircraft outdoors on the ramp, I use B+W graduated ND filters.
The 502 is better than the 501 .. it drops the bright blue sky 2 stops so I get more detail under the aircraft.
http://www.bhphotovideo.com/c/product/10458-REG/B_W_65063819_72mm_Graduated_Neutral_Density.html
Cheers.
Drink more tap water. On admission at Sydney hospitals more than 5% of day patients are de-hydrated.
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
