external audio for xa10 at DVinfo.net
Go Back   DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
For the Canon XA25, XA20, XA10 and all VIXIA / LEGRIA Series AVCHD camcorders.
Old August 4th, 2011, 07:37 AM   #1
I got the xa10 in addition to my canon 60D for video. For the price, I really like everything about the xa10. I am not very good with audio so I want to see if I can get some help/suggestion from those with more experience.
Here is my problem: I am using the Rode video mic pro(it uses the 3.5mm connection, not xlr connection) as external mic for the xa10. I notice when I use it as the external mic, I hear a lot of "buzzing" noise (I am sure there is a better term for "buzzing"...but lots of background noise). This mic works well with the 60d with no "buzz/background" noise.
XA10's audio setting:
Audio Mix: OFF
Mic terminal Input: LINE (when set to "MICROPHONE", the "buzz/background" noise is very noticeable)
Microphone Attenuator: ON (when it is to "Automatic", the noise is very noticeable. I am not sure what this function is for)
My question:
-What can I do to minimize the noise?
-Would it make sense to get a 3.5mm/xlr conversion cable and plug the mic into the xlr port?
Any help appreciated....
Aaron Leung is offline   Reply With Quote
Old August 4th, 2011, 05:41 PM   #2
Re: external audio for xa10
Not sure exactly what the problem is, but clearly the VideoMic Pro circuitry is not playing well with the XA 10's 3.5mm audio section. I think this sort of thing does happen more often with non-balanced inputs.
It would certainly be cost effective to try the 3.5mm/ XLR cable and use the XLR input. That could well solve the problem.
Otherwise, you may need to use a phantom power/XLR mic (like the Rode NTG-1) to get the best audio.
Bob
Old September 3rd, 2011, 05:25 AM   #3
Audio Mix: OFF
My question:
Use an XLR mic.
Set your audio completely in manual
Mic input to Mic
It may well be the mic you are using, what level have you set it to? Try a 3.5 to XLR adaptor, very cheap, it may help.
Battery or phantom power should not make a lot of difference
Colin
Colin Rowe is offline   Reply
  You are here: DV Info Net > Canon EOS / MXF / AVCHD / HDV / DV Camera Systems > Canon XA and VIXIA Series AVCHD Camcorders
