HV20 noise when tilting camera body at DVinfo.net
Old June 19th, 2007, 12:49 PM   #1
I just received a replacement HV20. The problem is that this new replacement also sounds like something is loose in the camerabody housing.
I am not talking about a loose screw or item in the camera housing or cassette mechanism. It is not the rattling sound of item falling around.
If I tilt the camera at a moderate speed up and/or down, then one hears something slide and "clink".
What could this be?
Checked the following:
- not the battery (which is just a little loose, that way on both models)
- not the plastic covers for any of the ports.
- not the metal rings on the hand strap.
- not the image stabilizer (loose sound with it on and off)
Do anyone elses HV20 have this issue?
Jimmy Finn is offline   Reply With Quote
Old June 19th, 2007, 01:21 PM   #2
This is the optical image stabilizer, EVERY HV20 makes this noise. It's been discussed here in multiple threads. The sounds coming from your HV20 are normal.
Clips | Stills
Wes Vasher is offline   Reply With Quote
Old June 19th, 2007, 03:18 PM   #3
Thanks for the quick reply.
I did search the forum for information, but didn't find any.
I will work around the noise from the image stabilizer then.
Does the OIS on the Canon XH-A1 also have this noise issue?
Old June 19th, 2007, 05:17 PM   #4
It's the OIS - noisy darn thing... totally normal, but yes it does freak one out.
FWIW, I put velcro dots on my batteries to stop them clunking around... big improvement...
AND to lessen body noise, I mount this cam on trpod or brackets...
Dave Blackhurst is offline   Reply
