Lens hood or shade recommended? - Page 2 at DVinfo.net
Old June 1st, 2007, 04:26 PM   #16
Its a mattbox + reg frenchflag from cinetactics.com. No vignetting and very portable.
Victor Horz is offline   Reply With Quote
Old June 4th, 2007, 08:11 PM   #17
I got one of the cheap ones off Ebay. It doesn't block the auto focus from what I could tell. I zoomed in and out a bunch of times and it didn't have any problems focusing.
It fits well, and it came with a cover. It fit perfectly on my UV filter.
Jules Ruez is offline   Reply With Quote
Old June 5th, 2007, 12:54 AM   #18
Lens Hood?
Originally Posted by Victor Horz View Post
I went straight for the mattebox+frenchflag for shade/hood
Hi there, thanks for posting the pictures, how is this setup working for you? Where could I buy that nifty lens hood that you've got on your HV20? Do you like your shotgun mic that you've got on there?
Canon HV20, Canon Powershot S3 IS, Canon GL2, Archos Gmini 402 Camcorder
http://www.SandHillStudio.net
Scott Turkington is offline   Reply With Quote
Old June 5th, 2007, 04:52 AM   #19
http://www.cinetactics.com/Page.bok?template=c_mb100m
You can get it from the above
Paul Petrou is offline   Reply With Quote
Old June 5th, 2007, 07:51 PM   #20
But how do you get that 'mattebox' to attach to the tapered front of the HV20 without having that wide-angle lens threaded to the front (or whatever attachment you have on there)?
David Garvin is offline   Reply With Quote
Old June 5th, 2007, 08:36 PM   #21
You don't. I suppose you could just get a step-up ring, say a 43mm to 75mm or something like that and then attach the shade to that. Dunno if the step-up ring would be thick enough, but it might work. Keep in mind though, because of the size of the shade, you are gonna lose the ability to use Auto-focus, the light and the flash.
Toby Bates is offline   Reply With Quote
Old June 5th, 2007, 08:39 PM   #22
Yeah, I don't like that hood anyway; I was just wondering how it might even work on the HV20 without additional hardware.
Old June 7th, 2007, 03:38 PM   #23
How come some people can post pictures and others cannot? I want to post a picture of the Fotodiox hood on the hv20. Looks nice. The instant focus sensor is blocked with it on however.
Marc Ramirez is offline   Reply With Quote
Old June 8th, 2007, 11:02 AM   #24
Received my hood yesterday!
Ian Albinson is offline   Reply With Quote
Old June 8th, 2007, 11:12 AM   #25
Ian - You can't mount the hood without a filter right? (At least you couldn't on the one I got from GoShot camera - ebay seller). So the problem is, with a standard UV filter you get reflections/flaring from the glass filter (more expensive coated ones perhaps not). With the UV they sent with the hood I noticed the flaring right away. So I returned it and ordered a 43mm hood that screws directly to the camera itself.
Peter J Alessandria is offline   Reply With Quote
Old June 8th, 2007, 11:22 AM   #26
Actually it came with a 43mm ring, and that's how it mounts to the camera. That ring is also threaded, so you could either add filter + ring + hood, or ring + filter + hood without an issue.
Old June 8th, 2007, 11:45 AM   #27
Did you notice any issues with the autofocus? That hood looks great!
Miguel Quiles is offline   Reply With Quote
Old June 8th, 2007, 12:32 PM   #28
It seems to slow the I-AF down a little, but that's not really an issue for me.
Old June 8th, 2007, 12:55 PM   #29
I've also ordered one of these for my wide angle WD-H46 lens. It's not the standard H43 that Canon recommends, but with a step-up ring it's been working very well, though flare is a big issue. Hopefully this will solve it.
Old June 10th, 2007, 05:39 AM   #30
Actually I recieved mine yesterday, it's the same as Ian's but in black. I mounted the supplied ring in front of my B&W UV filter and I set it so I can easily screw it on and off without re- adjusting the set screw.
I hardly notice any interference with IAF, if any......
Jeroen Verhoeven is offline   Reply
