HV20 Stream files at DVinfo.net
Old May 24th, 2007, 10:59 AM   #1
HV20 Stream files
I have two questions about the files that Premiere generates after a capture from the HV20:
1\Why Premiere saves them as mpeg files? Isn't it supposed to save them as m2t? How can I resolve this?
2\Is there a way to read the settings I used in a video from the acquired file? Shutter, aperture etch.
Thanks in advance.
Daniele Lauretti is offline   Reply With Quote
Old May 24th, 2007, 01:21 PM   #2
Thanks in advance.
I'm pretty sure I read that m2t files are mpg. You can even rename an m2t to mpg.
John Hotze is offline   Reply With Quote
Old May 25th, 2007, 09:17 PM   #3
They are indeed a variant of an MPEG file, but just converting the extension to mpg will not necessarily make it playable. For example, on the Mac systems, that will not suddenly make Quicktime able to play back the m2t without an appropriate codec (if anyone knows of one, please list it).
I've used VLC player (available for a whole variety of platforms) to view .m2t files without much issue.
As for Daniele Lauretti's concern, I wouldn't really worry about the format that's captured. I'm fairly sure there is no extra level of compression added in the capture process between saving .M2T or .MPG, and if you are planning on working with Premiere files it would probably be better to continue working with .MPG files anyway.
As for the second question, I think that if you have a mini-SD card in your HV20 and you snap a picture while filming (maybe this will work when playing back too?) the picture will have the EXIF data for the aperture, shutter speed and other information, but I don't think that you will be able to get the data from the MPEG file itself.
Kelly OHara is offline   Reply With Quote
Old May 25th, 2007, 10:32 PM   #4
Yes Premiere will capture the file as .mpeg. M2T is another MPEG file type (transport stream). I would suggest best way to capture is to use a free tool called HDVsplit. It will capture the file in .m2t file extension. Just google it!
Premiere consumes way too much overhead. I hated it Premiere automatically import the new capture file to the current project and force the conforming process.
Taky Cheung is offline   Reply
