Cheap solution to missing LANC... at DVinfo.net
Old May 23rd, 2007, 10:00 PM   #1
I read some posts about using a TOSLink optical cable to "route" the remote control signal to the front of the camera. I ordered a 3" TOSlink cable for $2.5, mounted the remote control to the tripod handle, wired the cable around the center pole, taped the other end to the front of the tripod. IT WORKS!!!!
Old May 23rd, 2007, 10:27 PM   #2
Can you please let me know where you got them from? I cannot get for the price you mentioned!
thanks
Ajit B.
Ajit Bikram is offline   Reply With Quote
Old May 23rd, 2007, 10:43 PM   #3
I bougnht the cable from here
http://www.firefold.com/ProductInfo....ctid=TOSLINK-3
Old May 24th, 2007, 03:33 AM   #4
Nice! I wish the remote had more functions, but this works well enough.
DIY, 35mm, HV20:
http://www.primitivebuteffective.net
Mike Dulay is offline   Reply With Quote
Old May 24th, 2007, 08:59 AM   #5
Originally Posted by Taky Cheung View Post
Thanks!! I am going to order now!
Old May 24th, 2007, 09:23 AM   #6
Hi Folks,
Check my post and photos in the "Remote Lens Controllers" section under "Want to Rig up your Infrared Remote ??"
I've been using this set up for many years, with all 4 of my Sony Cams set up this way.
My stuff is set up "plug and play".
Harold
Harold Schreiber is offline   Reply With Quote
Old May 24th, 2007, 11:07 AM   #7
Thanks for the tip guys, I'm on it....
Chris J. Barcellos
Old May 24th, 2007, 01:47 PM   #8
clever! nice find!
DJ Lewis is offline   Reply With Quote
Old May 24th, 2007, 02:10 PM   #9
Great idea and find. Just order one. Thanks.
Duane Steiner is offline   Reply With Quote
Old May 24th, 2007, 02:13 PM   #10
Here is Harolds solution...
http://dvinfo.net/conf/showthread.ph...nfrared+Remote
I also like the way he mounted the remote to the cable...
This might work very well outfitting this in a underwater housing...
If you can get he housing control buttons to align with the remote control
buttons..
Old May 24th, 2007, 02:18 PM   #11
Hi Ray,
That's why I call it "Plug and Play". I have a TosLink connector attached to each of my 4 Cams, and to each of my 4 Remotes (3 on removeable cradles).
Then I can leave the fiber-optic cables attached to my Tri-Pods and just plug everything in when I set up.
Harold
Old May 24th, 2007, 02:24 PM   #12
Hi Taky....very clever idea. What functions can you activate with this rig up.?? Will it work with any Toslink??
Luis
Luis A. Diaz is offline   Reply With Quote
Old May 24th, 2007, 02:28 PM   #13
As you can see here, I am not the first one who come up this idea. I read many posts on the internet about re-routing IR signal through a TOS optical cable.
I believe any regular TOSlink cable will work. Whatever functions you have on your remote control will work too.
Old May 24th, 2007, 04:14 PM   #14
at a distance.....
Looking at a slightly different application here....will the cable pick up IR without being right in front of the remote. I noticed on Takey's second pick that the cable end seems to be 90 degrees to the IR sensor on the camera.
The reason I ask is that in my living room the cable box sits in a entertainment center while the TV is on a different wall in the corner. If you sit close enough the cable box will pick up the remote but farther back and the angle is too great. If I take a TOSlink and mount it on the corner of the entertainment center where it is exposed to more of the room will it pick up the remote from accross the room?
Randy
Randall Allen is offline   Reply With Quote
Old May 24th, 2007, 05:37 PM   #15
Randal, probably not the way you imagine. The toslink captures a narrow portion of the beam from the remote and allows some play to it. But you still have to aim the LED pretty much directly into the cable to capture enough of the signal to pass on to the sensor. It also can't be too far from the cable. One possible solution to your problem is to reflect it on something.
http://www.flickr.com/photos/missilemike/491779741/
DIY, 35mm, HV20:
