#16 |
That would be great John, looks like it should work, it's the same size as the HV20. Post us up a clip once you get some shots with it. I saw a clip using the Wide Angle that Canon makes that someone posted on here and I was impressed, it looked really nice.
Canon HV20, Canon Powershot S3 IS, Canon GL2, Archos Gmini 402 Camcorder http://www.SandHillStudio.net |
#17 | |
I'm anxiously waiting for John Hinkey to test his Raynox HD-6600. If the results are good, I'l get the HD-6600, but in 52mm size which is much more common than 43mm.
Thinking out of the matte box. |
#18 |
My Raynox HD-6600 finally came this week and I threw it on the camera and just looked at the image in the viewfinder.
Unfortunately I bought a silver-colored step up ring and the front of the ring causes a lot of internal light reflections. I'm going to paint/color it black on the inside and post some results perhaps Sat. night. Prelim. first impressions are that it does get a tad bit soft at full zoom, but this was with a wide open aperature in a fairly dark room. The corners looked OK on the LCD in my living room and barrel distortion was not noticeable. Build quality was fairly good (I'm used to the build quality of Nikkor lenses) and does appeart to have single optical coatings looking at the reflections of lights in the front/back elements. I plan to find a brick wall somewhere (local high school should do) and take some stills at various zoom and aperature settings. Hopefully will get something posted (stills only) this weekend. Stay tuned - John |
#19 |
Thanks for the update. Looks like I made the same mistake by ordering a silvery Cokin step-up ring. Never even thought about it, just went for the thinnest ring I could find. Bummer... I'm not sure if I'll be painting it though, I don't want to have paint dust settle on the optics.
#20 |
Oooh, many thanks for that bit of insight. Scratching the Cokin off my list.
Andrew.
"The future is already here. It's just not very evenly distributed." - William Gibson |
#21 |
Argh! The weather here has forced me to put off taking some still images with the Raynox on the HV10. Maybe tomorrow if the rain lets up. I could snap some interior shots, but that wouldn't really be all that interesting now would it.
-John |
#22 |
HV10 + Raynox HD6600Pro:
Well, I took a bunch of 1920x1080 still images of a brick wall at the local high school, but alas I do not have permission to post attachments. How do I get permission to do this? So, I took stills (super fine/highest quality) over a series of fixed aperatures (F/8.0 to F2.8) with and without the Raynox attached. Unfortunately I bumped up against the 1/500 sec max shutter speed at F/4.0 and F2.8 and bright sun, so the images got brighter with the highlites burned out a bit, but you can still see any softness and some of any CA. The wall was about 10 ft. away, so the focus point was defintely not at infinity. Need a bigger brick wall and a rain-less overcast day. Anyways, lacking the pictures I can say that at full wide the Raynox exhibits a little bit of softness and CA, but it's not bad and may not be noticeable. This was at the min aperature (F8). At F2.8 it does get a slight bit worse, but not horrible. Full zoom is not recommended. Center is clear, but the edges are really bad. With the Raynox on I zoomed in a little from full wide and the edges were really quite good. Anyways, when I can have attachments I'll give photos along with commentary and you can see for yourself. Right now I have to say that I may get the Canon WD-H37C since if has full zoom through and maybe a 0.5x for really wide angle only shots (Century Optics single element?). More to come - John |
