#46 |
#47 | |
Anyway are the avs files getting created? If DGIndex runs properly you should have 3 files created, one avs, one mpa and one d2v. Just open the avs file with notepad and look for any obvious problem. It should look like the same one Steve posted with _vid_ and _aud_ replaced by the clip name with d2v and mpa extensions. Edit: and also one more command "delayAudio" at the end. |
#48 | |
#49 |
If you have no files being created, it sounds like DGIndex is failing long before you get to VirtualDub.
Can you try manually running through the DGIndex and see what error that application is raising to you? My app will get the process exit code from DGIndex and if it is non zero (error code), then it should not proceed to VirtualDub. So odds are it may always return zero on exit. Manually running through it should help identify the problem though. --Steve |
#50 | |
#51 | |
1)run the DGIndex just manually (not through Steve's exe) and see if it runs or not. 2) Look into the first post from Farnsworth in the other forum. And try running it manually (not using Steve's exe) 3) I hope you did install DGDecode.dll and mpasource.dll in avisynth plugin folder. 4) You would also need xvid/divx. Xvid is available from http://www.koepi.org/xvid.shtml Hope this helps. Ajit B. |
#52 | |
I somehow think its due to absence of Xvid/divx. Do you have them installed? |
#53 |
#54 | |
#55 |
I cannot think of what else could be wrong! Did you try launching DGIndex manually?
I didnt get the HDVSplit issue! I thought you already captured your footage from the camcorder, right? Anyway I am listing my setup below. Try finding anything that could be different than yours. 1) My Machine is Win XP sp2. 2) In C:\Program Files I made a directory called "HDV Utilities" in which I have HDVSplit.exe, DGIndex.exe, hv20pulldown.exe and template.avs 3) I also installed avisynth- which got installed in C:\Program Files\Avisynth 4) Copied the DGDecode.dll and mpasource.dll in C:\Avisynth\plugin also the TIVTC plugin. 5) Installed VirtualDubMod in C:\Program Files\VirtualDubMod. And this is the way I run: 1) Capture m2t files first using HDVSplit to D:\video\capture 2) Launch hv20pulldown -- specify all the paths and working directory as D:\video\pulldown 3) load the clips and run. I hope this would be of help. Ajit B. |
#56 |
#57 | |
#58 | |
If the clips give some problem with other viewers/NLE's it has to be the capture process. Hope you can fix it soon! Good Luck! |
#59 |
It certainly sounds like there are some problems with the original clips themselves.
I did find a couple threads about some of your errors though, maybe one will help resolve the problem. http://forum.doom9.org/showthread.php?t=113811 http://forum.videohelp.com/topic329046.html http://www.videohelp.com/forum/archi...g-t325577.html --Steve |
#60 |
Steve, thanks for those links. Will read them over to see if anything can help. Tried to tape some more footage and it did not work either. I hope I can figure this out.
