Component out faulty at DVinfo.net
Old May 14th, 2007, 09:57 AM   #1
I have been using HDMI output up to now but when I tried the component output there was no red channel signal. After much swapping of connections I found that the Canon-supplied cable was to blame - if you wiggled it where there is a black connector block the signal appeared.
It's a pity that Canon used a non-standard cable. At least I don't have to return the camcorder.
Bill Johnson is offline   Reply
