HV20 and my DVX100 XLR connecters
Im wondering if i could use the xlr connecters of my dvx100 to plug in an XLR mic with my HV20 by pluging the mic into my dvx100 and then pumping the audio out the throught the earphone plug into the mic input of the HV20 would i then get balance output from my DVX100 with out buying a beactech adapter ???????????
Woah, Marty chill. ;-)
The Beacktek DXA-2s is a good solution for the HV20 but if you don't want to spend $180 try one of these first: http://www.radioshack.com/product/in...tId=2062443&cp $14.99 You'll also need a 1/4" to 1/8" (mini) adapter. $5 |
thanx peter how good will this work for sound with a nice mic on a boom pole running into the hv20 ? will i get about the same results ??
Your're right that your can use long mic cables to the DVX, which will be balanced. You can even use phantom powered condenser microphones. As cameras go, the DVX100 has exceptionally good audio specifications, i.e pre-amps and AD conversion.
However, it is possible that the headphone output is, in comparison, crap. Also I don't know whether it is the right level or impedence for a microphone input. An option, would be to actually use the DVX100 to record the sound. DV audio is a higher quality specification than HDV audio, and all the audio circuits in the DVX100 are likely to be better than the ones in the HV20. So, for any microphone, the DVX100 will always sound better than the HV20. The only disadvantage, would be that you would have to use your NLE to put the DVX recorded sound back with the HV20 picture. Patrick |
#5 | |
If you really want to drag your DVX around while shooting with your HV20, you can just use the AV output on the DVX rather than headphone jack (you can get an RCA to mini plug adapter at any RadioShack.) Of course, the Beachtek is still the way to go on this - very clean and convenient. |
#6 |
wild combinations
Wow. This thread is getting pretty wild. Record audio on an old camcorder and record video on the new camcorder to avoid an adaptor like the Beachtek or the XLR Pro. Then import the audio into an editor and try and sync it with the video. Way out. Or drag along another camcorder to act as an XLR converter for a mic. Wild.
I'd also like to see where it states that DV audio is better than HDV audio. That's a new one for me. I'm collecting and researching data by the way. I'm new to HDV and I'm on a steep uphill learning trail. BTW. I'm carrying my older two Canon camcorders along on all my shoots as a backup and possibly a second & third angle shoot if I have some friends willing to help. One thing I caught Peter was if you used a dynamic XLR mic, you wouldn't have to worry about phantom power. I wanna hear how Marty plays this one out. |
#7 |
"I'd also like to see where it states that DV audio is better than HDV audio."
Look at this thread: http://www.dvinfo.net/conf/showthrea...&highlight=384 Patrick |
#8 | |
Lots of info on HD audio versus SD audio
