HV20 Latitude and exposure details - Page 2 at DVinfo.net
Old May 9th, 2007, 12:43 PM   #16
Originally Posted by Noah Yuan-Vogel View Post
as I understand it, brightness just affects autoexposure. I would probably put brightness at -1 to avoid clipping highlights
Can you elaborate on this? Adjusting the brightness value doesn't seem to have any effect whatsoever on my HV20.
Steve Brady is offline   Reply With Quote
Old May 9th, 2007, 12:50 PM   #17
right, i was told it will just affect what the autoexposure considers to be correct exposure. So you might see a difference if you change the setting with autoexposure on, or maybe if you turn it on, put it in manual exposure and then back to automatic. I'll check when i get home. In any case, it doesnt seem that important unless you use autoexposure a lot.
Noah Yuan-Vogel is offline   Reply With Quote
Old May 9th, 2007, 04:44 PM   #18
Thanks Noah
I think Im getting my head round it all now
Fergus Anderson is offline   Reply With Quote
Old May 16th, 2007, 09:05 PM   #19
This is an interesting thread. I'm just curious though, what camera is the D20? The only D20 I know of is Canon's EOS D20 digital SLR.
Glenn Thomas is offline   Reply With Quote
Old May 17th, 2007, 08:09 AM   #20
I dont see a D20 mentioned anywhere in this thread... what are you referring to?
Old May 17th, 2007, 10:27 AM   #21
The Arri d20 was mentioned earlier...it's a $100,000 digital camera I believe. Someone did a chart comparison in another forum showing how close the HV20's picture was to this cam....kind-a-scary.
http://www.arri.com/prod/cam/d_20/d_20.htm
Ian G. Thompson is offline   Reply With Quote
Old May 17th, 2007, 10:50 AM   #22
Ohhh, that D20. right right. Yes that is the Arri D20. Sorry, and I'm the one who mentioned it :P . Yeah then again the Arri D20 has a ~3k 35mm sensor i believe so its hard to really compare with the HV20. I think the original graph was for cameras at ISO320, and I'm guessing the HV20 wouldnt do all that well at ISO320 as it would probably have to gain up full stop.
Old May 17th, 2007, 06:58 PM   #23
I just performed an ISO test with the HV 20. At 24p 1/48 F2.0, the camera is achieving 120 ISO. This seems right considering its small chip and high sensor count.
Brian Tori is offline   Reply With Quote
Old May 17th, 2007, 10:51 PM   #24
Sounds like what I'd expect. I wonder what a quantitative noise test would tell us about the sensor's performance at that level.
