Contacting Canon re: adding 24p pulldown flags - Page 7 at DVinfo.net
Old May 9th, 2007, 07:49 PM   #91
Originally Posted by Thomas Smet View Post
This is not a fix but a after market feature request. The camera is not broken and it works exactly like it was designed to work.
I concede. "If it ain't broke don't fix it."
Ian G. Thompson is offline   Reply With Quote
Old May 9th, 2007, 07:55 PM   #92
hv10 deinterlance footage
4:2:2 conversion
film gamma
http://jya.jp/jt/tmp//1178759146.wmv
Jung Kyu is offline   Reply With Quote
Old May 10th, 2007, 07:44 AM   #93
I stand firm in my position that this is NOT a big deal. So what if canon engineered this camera so that it takes 1 extra step (a very simple step IMO) to get the true 24p. I am glad to see that Ian G. came around to agree that this camera "ain't broke, so don't fix it." I don't get it. What's so hard about doing reverse telecine instead of 2:3 pulldown removal??? What? You say your software doesn't do reverse telecine. Maybe it's your software you should be trying to change. Not your camera. The software package I owned had no problem doing what needed to be done simply, and quickly, with the HV20 right out of the box.
Last edited by Pete Bauer; May 10th, 2007 at 10:27 AM. Reason: "platform war" text removed
Stefan Szabo is offline   Reply With Quote
Old May 10th, 2007, 07:57 AM   #94
What is the proper workflow on a mac and what software should be used?
I have a macbook pro. I have the canon hv 20. I will shoot in 24p very soon. What software exactly do I need. I'll purchase either final cut pro or final cut express. I need step by step being a new person to this whole 24p capture, etc. etc. To the pros out there, it's a no brainer apparently. Yet for me and many others like me interested in using this new camcorder as well as the proper software, we need a little more hand holding and less assuming we have the experience of what to do. So a step by step procedure would be most welcome.
i.e. step one, capture footage using this software with these settings. step two, use the following setting and then export using the following settings. step three, using nle software, import using the following settings. when done editing, export using the following settings. If exporting hd, use this setting, if exporting to dvd use this setting, if exporting to blueray use this setting, etc.
Now that would be helpful. In fact, the person would get quite a following who offers that type of specific advice. The question is, who will provide this information.
Thanks in advance to whomever answers the call. Your name will live in glory to all those who stood on your shoulders to take the next step.
Vincent DePaul is offline   Reply With Quote
Old May 10th, 2007, 08:03 AM   #95
Please describe your "very simple step", because from the numerous posts I've read, and the experimentation I've done, it's not that easy, especially since it requires you to duplicate all your footage. Maybe I'm missing something through...
Ian Albinson is offline   Reply With Quote
Old May 10th, 2007, 08:57 AM   #96
Windows: Capture direct from camera with Connect HD.
Mac: Capture direct from camera to AIC Codec. Reverse telecine with Cinema Tools
So technically, it's only one step with windows, two steps with the FCP / Cinema Tools workflow. With Cinema tools you have to remove pulldown manually, and set the start frame.
Solomon Chase is offline   Reply With Quote
Old May 10th, 2007, 09:06 AM   #97
How to get true 24p with Final Cut and Cinema Tools
I use Final Cut Pro and Cinema Tools to get the job done. Cinema Tools comes with the Final Cut Studio Package.
Step 1. Open Final Cut Pro, Close any projects that might be open, go to Final Cut Pro>Easy Setup. Choose HDV 1080/60i.
Step 2. Go to Final Cut Pro>Audio/Video Settings, and under Capture Preset choose HDV Apple Intermediate Codec -- (Very Important!)
Step 3. Open a new project (unless one opened automatically), Open Log and Capture, and Capture footage just as you would normal dv footage.
Step 4. Save your project!!!!! Close Final Cut.
Step 5. Now here is the extra step that people are complaining about. Instead of removing pulldown in final cut, you have to do it in Cinema Tools....It really is easy once you know how to do it. (takes a while to explain, but is quick when you do it)
First, each clip you capture must begin with the first progressive frame in the sequence of three.....Sounds complicated? it's not really. Because of the HDV Standard, clips are captured in a sequence of 2 interlaced frames, then 3 progressive frames, then 2 interlaced, then 3 progressive, and so on.... I've seen it like this- iipppiipppiipppiippp - you must trim your clip so that it begins on the first progressive frame in the sequence of 3. Easily done by going to your capture scratch and opening you clips in quicktime. use the arrow keys to advance frames one by one. It is pretty easy to tell which frames are progressive, and which are interlaced. command-x removes the current frame. Once you have it to where the first three frames of the clip are progressive, save and close quicktime. Then Open Cinema Tools and click cancel when it asks to open a database. Go to File>Open, choose your clip. Now click Reverse Telecine, the button on the right side of the viewer. Set it to 23.98 frames per second, and click DD at the bottom. Click ok and save it. Once it's done. You've got true 24p. Import the clips into a Final Cut project, Got to Sequence>Settings, and Change the Timeline to 23.98 FPS. Now you can edit in 24p. I haven't really messed around with the export settings, but I'm sure it would be easy to figure out.
I know that it seems like a lot to do this, but you'll see that once you try it, it really is a very simple and quick process, and Totally worth it to get the quality. It's not really worth complaining over, especially because of the price and features of this camera.
Old May 10th, 2007, 09:50 AM   #98
Well, it's always impressive to stand firm, but it's not a qualification for being right, just the appearance of it. People who bluff do it all the time.
If you say it's not a pain to go through these extra steps when Canon could have added flags then you're not being forthright, it is a pain. In the patuskie. Time is valuable, and the necessity of spending my time doing these extra steps, taking up valuable space in my hard drive is a temporal and physical waste and a mental drag.
Canon could easily have added the flags but they didn't, just like they didn't have a mic input in the HV10. Who's taking bets the HV30 has flags?
It's probably not an engineering problem, it's a suit-n-tie problem, someone's decided on the way to maximize cashflow.
Elmer Lang
Elmer Lang is offline   Reply With Quote
Old May 10th, 2007, 10:45 AM   #99
You say "Canon could have easily added flags", but honestly, how do you know that?? Apparently you are an expert engineer in digital video and optics.....Either that, or you assume that just because it is in the high end Canon's, it is easy and should be in this camera also........Either way....It doesn't really matter. There's no point arguing who is right and who is wrong.
The fact is, if you want 24p with the HV20, you have to reverse telecine....If your editing time = money, then you are considered professional. And if you are professional, why are you using a consumer grade camera? This is a Non-issue for me, as I am extremely grateful to be able to even afford the chance to work with true 24p.
Old May 10th, 2007, 11:13 AM   #100
Hey mac guys who are having reverse telecine issues:
this thread here gave me a nice workflow:
http://dvinfo.net/conf/showthread.php?t=92629
Yes it involves duplicating your footage, but it's a one-time thing (from HDV->Photo-JPEG). Besides, cutting in native HDV just yields nasty generational issues.
Ryan P. Green is offline   Reply With Quote
Old May 10th, 2007, 02:28 PM   #101
Stefan, one thing is to realize that this is a consumer camera. It is listed such here:
http://www.usa.canon.com/consumer/co...categoryid=173
If they would list in under professional cameras here:
http://www.usa.canon.com/consumer/co...categoryid=172
and clearly state the limitation in 24p mode I would be fine with that.
How many consumers do you expect to be happy with paying extra $250 for Connect HD (don't quote me on the price please) on top of what it comes with he cam and/or additional sub $100 NLE they already might have?
How many consumers are going to be happy with interlaced artifacts when watching out-of-box video?
I did not have to do all this with my JVC HD10 or HD1, both pro and consumer versions.
Unfortunately the whole 24p is so cloudy when you read about it on canon.com or the pdf downloadable manual. Either they do not know what they are doing or they put the big cloud on it for legal reasons.
You can take any 1080i cam and run it through NLE to get progressive like 24p. If this is acceptable then there are many cams to choose from. Most would buy this cam for the 24p mode.
Again, this is a consumer cam and it doesn't deliver out-of-box performance.
When this issue is addressed I get one the same day....it is canon's opportunity to get a nice market share....
Peter Frollo is offline   Reply With Quote
Old May 10th, 2007, 02:57 PM   #102
Getting back to the original point of this thread, just a quick update: spent nearly 1 hour on the phone today with Canon tech support (the Irvine Calif.Canon Service Center deflected the call that way). I spent most of the time on hold as my support rep kept checking with other people in the organization. By the end of the call (which was very cordial BTW) she informed me that someone in upper management would be made aware of the issue and would contact me directly within a week or so.
I also called the Canon R&D Facility in Irvine Calif. The woman I spoke to was not helpful and all I could get was a fax number to send a letter to voice my concerns. For those who like writing letters: it's 949-932-3510 I'm sure a few hundred (polite!) faxes would get their attention.
Peter J Alessandria is offline   Reply With Quote
Old May 11th, 2007, 12:51 PM   #103
Originally Posted by Peter J Alessandria View Post
Getting back to the original point of this thread, just a quick update: spent nearly 1 hour on the phone today with Canon tech support.
I also called the Canon R&D Facility in Irvine Calif. For those who like writing letters: it's 949-932-3510 I'm sure a few hundred (polite!) faxes would get their attention.
Thanks for your efforts!! I faxed the number you provided with a polite query and hope others will too. Please let us know of any developments.
best,
elmer
Old May 11th, 2007, 02:28 PM   #104
Thanks for all the efforts to make the HV20 a better camera. I have emailed Canon as well.
Here is a thread at AVSforum about this topic: http://www.avsforum.com/avs-vb/showthread.php?t=843628
Mike Naughton is offline   Reply With Quote
Old May 11th, 2007, 03:12 PM   #105
CTO, CineForm Inc.
I haven't been following this thread until I noticed the number of times CineForm is mentioned -- thank you for the complementry words.
CineForm extracts the pulldown using a real-time image analysis which we developed for a much higher-end application, it just works very nicely with these new HDV sources. We wouldn't use the flags even if they where there -- flags can be wrong, but the image doesn't lie. We don't use pulldown flags offered in the Sony V1U, as there would require engineering time to get the same result we have now. So asking for pulldown flags from Canon is the wrong request.
What you could be asking for is progressive encoding like the Canon HV20 big bothers XL-H1,G1,A1. These cameras encode 24p as 24p, not 60i. No flags are needed, as no pulldown needs to be extracted. The problem is the nature HDV NLE vendors are so slow to use this approach, Canon went with the lowest common demoniator for wider NLE support, which is 60i. Yet most NLEs don't support pulldown flagging in HDV anyway. So really you should be requesting wider 24F support from Apple, Sony and maybe Adobe (I think they have it) so then it would be fine for camera's like the HV20 to encode that way.
Non-pulldown 24p encoding of MPEG is more efficient, has fewer artifacts, and the 4:2:0 sampling will not produce any crosstalk between frames as it does with 24p in 60i.
my 2 cents.
