Thread Tools
Search this Thread
#46 |
CTO, CineForm Inc.
Yes. But try both NEO HDV and Aspect HD first, to see what you prefer.
David Newman -- web: www.gopro.com blog: cineform.blogspot.com -- twitter: twitter.com/David_Newman |
#47 |
1.0.0.15 of standlone
Steve, not sure if it's my imagination but the new 1.0.0.15 of the standalone process appears to run VirtualDubMod faster for the same codec settings (using WMV9 Lossy). I see you've appended some new lines to the syl file used for re-encode, are those performance tweaks?
#48 |
Steve, your .avs file may be blocked (because of the extension) by the web server itself. Try zipping it. If you need bandwidth (for downloads etc.) let me know and we'll set you up. I posted a link to your page over at dvxuser so folks there could have a look. Once set up, the standalone .exe is, IMHO, the easiest method to deal with HV20 pulldown removal I've seen yet. Having the .xml template that can be saved is a nice touch.
#49 |
Mike, are there new lines there for the .syl? When I made the template file conversion, I just write out the previously set defaults from my resource file into the new xml file. Those should be the same as they were before. At least I don't remember changing them! It's good to hear that it might be faster though.
Dennis, yes, it does seem like my IIS server is preventing those extensions for external machines. I renamed it to template.avs.txt and then it downloads just fine. I'm not too worried about bandwidth for this little app but I did go ahead and zip it up along with the avs file. I'll update the documentation shortly to point at the new zip file... --Steve |
