#16 | |
JES will handle Apple Intermediate Codec files as well, so you could certainly capture that way instead. |
#17 | |
Placed in a sequence with that codec the clip will play after rendering. It'd be nice not to have to render. |
#18 |
MPS Digital Studios
Which version of FCP do you have? Under Sequence Settings, you'll see QuickTime Video Settings. In there, set it to Photo - Jpeg, Quality at 75%.
heath
My Final Cut Pro X blog |
#19 |
I've heard this JESdeinterlacer program didn't have the capability to do FULL QUALITY output, but only did half. Did they come out with a newer/updated version? Meaning, if you wanted to have the same HDV quality that you input, you couldn't have it. It would output half the quality... Weird by that's what I heard
#20 | |
Anyway, it's a light, free program, so I'd encourage everyone to experiment with it and see if they find it up to snuff. |
#21 |
Hal, thanks for the info!
Bruce |
#22 |
#23 |
MPS Digital Studios
No problem, Elmer. Just remember, Photo - Jpeg at 75% quality gives you 4:2:2 YCbCr. Use it for DV, too.
heath ps-Graeme Nattress of www.nattress.com and RED Digital Cinema fame was the one who originally told me about this in 2005.
#24 | |
i just emailed Graeme, and he indicated that Nattress' Film Effects would not do this job... which is a shame. If it did, there's no chance i wouldn't pick it up - i wonder if we could prod him into adding it, seeing as how the HV20 keeps getting picked as a "best of"... there's going to be a lot of people using these as backup cameras and cameras put into harm's way in lieu of higher-end units. |
#25 | |
MPS Digital Studios
heath
#26 |
Here's my email to Graeme -
Subj: Film Effects and HV20 I'm shooting in the HDV 1080p24 mode which is telecined into HDV 1080i60. Also, each cut has a different cadence, meaning that i have to go thru and manually set the cadence each time i hit the rec/pause button outside of Final Cut with Cinema Tools. After all of that hard work - it actually looks pretty great... but the workflow is 3 additional steps and 4 times as long as using regular DV. Would your Film Effects software 1. be compatible with FCS2 (they had me at "Smoothcam") 2. be able to automagically detect the cadence and bring me the 24p footage i'm longing for? Thanks in advance. Here is his reply... Hi Don, Yes, it's a right pain to remove pulldown and I don't have anything that helps here either..... so 1) yes 2) no. The code in Film Effects (that does the image processing) can do really nice things to the images, whether they're 24p, 60i or whatever, but the 60i to 24p conversion is only for normal 60i footage. Graeme ______ btw: my workflow... HV20 in 1080p24 mode -> DVHSCap over firewire to .m2t files -> MPEG Streamclip to AIC -> Cinema Tools -> AIC with reversed telecine Last edited by Don Swetz; May 15th, 2007 at 04:19 PM. Reason: (wanted to give my workflow) |
#27 |
MPS Digital Studios
I checked my notes from NAB and I remember stopping by the Apple booth and seeing a V1u, so what does that mean for us? I can guess, grin.
heath
#28 | |
Contributor
workflow
on side note does anyone else have random issues with the JES deinterlacer? every once in a while there is a file that just won't do as it's supposed to, and JES quits mid stream |
#29 |
well, Final Cut doesn't treat HDV as 1920x1080 - it does it 1440x1080.
I convert .m2t's to AIC using MPEGStreamclip, and during that conversion, i make the files "native" 1920x1080. So that takes care of frame size. Everything from that point on is done in the size i'm going to be working with in the end. When i reverse telecine the clips in Cinema Tools, there it is - just the clip i was looking for. i've built a AIC 1920x1080p24 easy setting in FCP - bam. it all seems to work for me. I don't want to work in 1440x1080i60 - since that's not my final output. i've looked at http://www.hdvxdv.com/ - and its obvious that they used DVHSCap as the base for their product, but i can't figure out what i get for $80 vs. the way i'm doing it. i think i asked this question a few years ago when they made the DVDxDV product which took DVD video and transcoded it into .DV... in both cases, i used MPEGStreamclip to get to where i wanted to go. |
#30 |
MPS Digital Studios
Where do you find DVHSCap? The Apple developer page? I think I downloaded it.
heath
