Change shutter speed in cine mode? at DVinfo.net
Old April 24th, 2007, 01:42 PM   #1
Hi all
I have just got my HV20 woo hoo!
Its taking a bit of getting used to as its actually quite different to the HV10. In some ways I actually find the HV10 easier to hold...
anyway - when I first tried the HV20 I thought I managed while in 25p and cine mode to also change the shutter speed (up to 120), however after playing with the menu for a bit I cant remember how I did it?
Am I going mad or is it possible to change the shutter speed manually while in cine mode and 25/24p?? If not what is it set at? Is it 25 or 50 (cant make up my mind but hope it isnt 25!!!!)
Fergus Anderson is offline   Reply With Quote
Old April 24th, 2007, 06:32 PM   #2
Try here ... look for the reference to the cellphone trick
http://www.dvinfo.net/conf/showpost....2&postcount=39
From http://www.dvinfo.net/conf/showthrea...hlight=cine+48
DIY, 35mm, HV20:
http://www.primitivebuteffective.net
Mike Dulay is offline   Reply With Quote
Old April 24th, 2007, 10:49 PM   #3
i don't believe you can control shutter speed in cine mode. tv mode is the only mode you have manual control of shutter. cine mode defaults to 1/48 but the camera will automatically change that value as it sees fit based on exposure.
Henry Cho is offline   Reply With Quote
Old April 25th, 2007, 05:44 AM   #4
Ok thanks guys - for some reason I thought I could see the shutter speed option on the top left just by the cine mode indicator. Well I will give the lock trick a try!
I am pretty happy with the cine mode though - it picks lots of details which are over exposed in normal mode. I have used the standard sony sharpen tool in Vegas on raw cine footage and it looks really good (I find it a little too soft otherwise)
Old April 25th, 2007, 10:05 AM   #5
Cine Mode is too soft for me too. That, combined with the fact I can't control shutter speed, means I don't use it. To control highlights, I've turned down the brightness and contrast in the custom settings.
Peter J Alessandria is offline   Reply
