Thread Tools
Search this Thread
At what F stop is the HV10 sharpest with...
..if set in macro mode and focused on infinity? Anybody with an HV10 know from experience what range of F stop works best as I'd like a general starting point for setting up a 35mm lens adapter? Does the image degrade much when wide or tele?
Thanks, Alan |
Sorry, don't have an answer for you, but how do you set the HV10 into "macro mode"?
Honestly don't know
Brad, Don't know I'm trying to get info lined up to setup an HV20 with a 35mm adapter and the HV10 is pretty much the same. So I was asuming the HV20/10 had a macro focus function, will check the manual, but it may not. I know the lens is probably sharpest at a particular exposure, but I may just have to mess around until I get a good image. It is at least two weeks out anyway.
Regards, Alan |
