#16 |
Great job Chris. You might want to check the last paragraph as it still makes reference to the HV10 as a deck to play H1 and A1/G1 footage. I think you probably copied and pasted this from the original HV10 article. It might confuse some people so you might want to update it to make reference to the HV20 instead!
Thanks! |
#17 |
Thanks Marty -- now fixed. You're right, I'm such a hack that I did a cut and paste job on the whole lower half of that page. Too much to do and not enough time, as usual!
#18 |
That's not being a hack. That's working efficiently. Sometimes little things slip through the cracks! It's all good!
#19 |
It's too bad about the LANC jack. For operating on a tripod you often need a zoom controller and for remote mounting (car mounts, helmet mounts, etc) you might need to start/stop the camera from a cable. I guess we can't complain too much since the camera is so inexpensive but it's so tantalizing close to having no major limitations. The LANC jack limitation can be worked around, but the solutions are pretty ugly, like a fiber optic extension for the IR remote or a servo actuator for the zoom controller.
#20 |
chris h.,
i'm curious as to how many times prior to HV20 has DVI not report on somn and have the product debut as a 'surprise'. typically DVI'ers are the first ones to read/hear things about new products in the pipeline from different vendors. HV20 was a TRUE surprise for many of us here as we'd assume that HV20 was just a typo... but it turned out to be real. any other similar happenings in the past?
bow wow wow |
#21 |
Can you think of any, Yi? Because I can't even remember what I had for breakfast this morning.
DVI has never been concerned with being "first" with any news... all that matters is getting it right... |
#22 |
Chris: you had soylent green for breakfast. That's what you have everyday. ;)
Great job on the news releases. |
#23 |
Coming from a Sony HDR-HC3 , Will the HV20 allow you to use full manual mode and adjust the Gain, Aperture, and Shutter speed ? I can't do this on my HC3 . Also does Canon usually have some sort of interval record mode ?
Thanks Joey |
#24 |
Gain is either on or off. There's some control of iris and shutter. No intervalometer in Canons.
#25 | |
#26 | |
That JVC won't serve as a deck for my XLH1! Mike
Chapter one, line one. The BH. |
#27 | |
#28 |
I wouldn’t call it superior to the HC7 just yet. Its basically a tossup.
#29 | |
#30 | |
