HV10 + FCP = Capture? at DVinfo.net
Old January 16th, 2007, 10:22 AM   #1
Anyone having luck capturing HV10 to FCP? Is it separating into different files?
thanks,
elmer
Elmer Lang is offline   Reply With Quote
Old January 16th, 2007, 01:21 PM   #2
Images: 8
What's your particular problem and what version of FCP are you using?
Tomas A. Chinchilla | CANON XH A1, HV20 & HC3 | Retired Cams: GL2, HC1, FX1, Z1, | Final Cut Studio 2
Tomas Chinchilla is offline   Reply With Quote
Old January 16th, 2007, 01:44 PM   #3
I've had problems capturing that I imagine are due to hardware/software limitations (1.33ghz PowerBook/FCP 5.0.4),
But other threads here and elsewhere note similar problems - batch capture files split, only able to capture using HDV firewire (can't capture using Apple Intermediate), etc.
Since I plan on rectifying my hardware/software problems (MacBook Pro 2.33/FCP 5.1.2) I was wondering if there've been any successful stories, or if maybe a patch is needed and awaited.
thanks,
elmer
Old January 16th, 2007, 02:57 PM   #4
Images: 8
I am just wondering if it's not a settings related issues. Like the second tab of the "Log and Capture Tab".
Old January 16th, 2007, 05:03 PM   #5
Try using iMovie HD - it says 'HDV 1080i' in the setup, but it is actually using the Apple Intermediate codec.
Just an idea.
Lee Wilson is offline   Reply With Quote
Old January 16th, 2007, 05:56 PM   #6
Images: 8
Just an idea.
That will not only result in a format conversion but will take far more space than necessary.
Old January 16th, 2007, 06:10 PM   #7
How does the intermediate codec convert - and what is it converting from ?
Old January 16th, 2007, 06:56 PM   #8
Images: 8
The Native HDV format is MPEG2, when you capture with FCPHD it wraps that MPEG2 so that it can edit it. In iMovie it takes that HDV and transcodes it into AIC and the resulting file is much much larger. MPEG2 @ 25MPS and AIC it's something much much higher.
Do a test capturing the same clip and you'll see the resulting size.
On the other hand, much people argue that the AIC conversion does not degrade quality but for some of us (I am a very picky person) we can actually see a difference.
Old January 16th, 2007, 08:04 PM   #9
Yep, appears in my tests that file sizes are over twice as large and I have also seen some quality differences. My best transcoding results quality wise (of course it takes time) is HDV to DVCPro 720p60 via mpeg streamclip, (doesn't look too bad.)
Rich Dykmans is offline   Reply With Quote
Old January 17th, 2007, 01:26 AM   #10
APP or SV
I was editing with Adobe Premiere Pro 2.0 and not capture in separate files (extension Mpeg), but now with Sony Vegas 7 it can do it (.m2t files extension). The export configuration was in 1080i, now i.m going to try 720p. format that can produce better results, i hope.
Ramon Quesada is offline   Reply
