Wide angle lens sample raw clip at DVinfo.net
Old January 11th, 2007, 07:48 PM   #1
Here is a sample clip showing before/after with the Raynox 5050 wide angle lens. It's a raw m2t file so although large, it shows the real thing.
http://www.filefactory.com/file/f74f7c/
I know file factory is a pain, but it's free.
For $90, I am impressed with the Raynox. Barrel distortion is acceptable IMHO. The edges do get soft, but I can live with it. The clip is shot at an angle so you can clearly see the edge softness. If it were shot straight on the softness would be less noticeable.
Ron Chau is offline   Reply With Quote
Old January 11th, 2007, 08:17 PM   #2
Thank you for posting!
Looks very good, clean and distortion free.
On a side note, on my PC when viewing HV10 .m2t files, I can not see any interlacing artifacts, I'm using VLC player and the de-interlace is set to none. And I know when viewing other 1080i material from FX1 I can see interlacing.
Whats going on?
The IT Ninja Learn, Teach, Grow..
Anhar Miah is offline   Reply With Quote
Old January 19th, 2007, 08:50 PM   #3
Thanks for this footage. :)
Welcome... to the real world!
Daymon Hoffman is offline   Reply With Quote
Old January 20th, 2007, 03:39 AM   #4
Thanks Ron, looks great.
Anhar, there really is interlacing. You just don't notice it that much because there isn't a lot of motion (and thus not much difference between the fields in every frame).
To show you, I posted a fragment of a still from Ron's clip:
http://www.filecrunch.com/file/~kptp61
Look closely at vertical features such as the bridge or the people walking.
Regards,
Pieter
Pieter Jongerius is offline   Reply With Quote
Old January 20th, 2007, 08:44 AM   #5
Can interlacing be avoided
… or at least softened?
I know how to do it frame-by-frame, in Photoshop
http://www.retouching.com/xinterlacing.gif
sorry! if it is unacceptable to use someone's borrowed frame : )
(I'll take it down if it is)
Laurentiu Todie is offline   Reply With Quote
Old January 20th, 2007, 09:58 AM   #6
You can de-interlace in just about any editing or compositing software and many media players such as VLC will de-interlace 'on the fly'.
To de-interlace frame-by-frame in photoshop is crazy talk 'round these parts !
Lee Wilson is offline   Reply With Quote
Old January 20th, 2007, 10:27 AM   #7
5 min. max
… my experience with video (HD or otherwise).
but I'm learning; thanks for the info!
I'm glad, but I think the results could be better.
Can someone post an example of de-interlacing in a video editing application of the same frame?
Old January 20th, 2007, 02:09 PM   #8
Hi Laurentiu,
I did a quick google for you to find something on interlacing and deinterlacing:
http://en.wikipedia.org/wiki/Interlace
http://en.wikipedia.org/wiki/Deinterlacing
(there must be better sources but this seems to cover it).
I personally think that interlacing is not all that bad because it gives us the opportunity to capture 200% smoother motion: 60 fields per second, as displayed on regular TVs, instead of just 30 frames. I even think this goes also for display on most LCD tvs, since they often deinterlace internally to 60p.
...but this thread was on wide angle footage I believe, sorry ;) There is tons of (quite advanced) stuff on (de-)interlacing in other parts of the forum.
Added: btw, most of the scaled down WMV or MOV video's that are posted here, are deinterlaced.
Old January 20th, 2007, 02:43 PM   #9
Thank you, Pieter!
Sorry for the hijack.
(I didn't start it, but "it" was touching one of my concerns)
