Sensor Size at DVinfo.net
Old November 27th, 2006, 05:58 PM   #1
Sensor Size
The sensor size is listed as 1/2.7". How do I read this spec? I don't see how to get 16:9 out of that number.
Don Miller is offline   Reply With Quote
Old November 27th, 2006, 06:30 PM   #2
The sensor size has no relevance to the shape of the target area matrix. The sensor could be oblong, trapezoidal, rhomboid, egg-shaped, star-shaped; it doesn't matter. All that counts is that there's a target area within the sensor that is 1920 pixels wide by 1080 pixels tall, and that the High Definition video target area within the sensor is 16:9 in shape. Which it is. At 1/2.7" in size, it's a fairly large image sensor compared to other camcorders in the same price range. Hope this helps,
Old November 27th, 2006, 06:37 PM   #3
I must be dense, but I still don't get 1/2.7". Does that mean one sensor with a 2.7" diagonal?
The XL H1 is spec'd as 3- 1/3"
Old November 27th, 2006, 08:04 PM   #4
Don its one sensor where the diagonal across is 1 divided by 2.7 inches= .37044 inches. A 1/3" sensor is .3333 inches. So the sensor on the HV10 is just a bit bigger than a 1/3 sensor. Its just the crazy way that the marketing guys have mixed up decimals with fractions ( obviously have no idea of mathematics !!!! or new it would confuse a large number of people.)
Ron Evans
Old November 27th, 2006, 09:23 PM   #5
Thanks Ron.
Interesting that the LCD is 2.7" and the viewfinder is spec'd at .27"
Old November 28th, 2006, 12:19 AM   #6
Expressing sensor size as a mixed fraction such as "1/2.7" is a crime in my opinion.
See some notes on this topic at http://www.dvinfo.net/canonoptura/ar...eage.php#opccd -- I wrote it for the Canon Optura line but it applies to the HV10 as well, more or less.
Old December 7th, 2006, 08:52 AM   #7
Check this link:
It's a little bit confusing, so I've got this explanation from DPREVIEW:
http://www.dpreview.com/learn/?/Glos...r_Sizes_01.htm
Hope this helps...
Etan Shirron is offline   Reply With Quote
Old January 14th, 2007, 12:32 AM   #8
It can be very confusing to understand a decimal in a fraction. It can screw with your mind.
Holly Rognan is offline   Reply With Quote
Old June 30th, 2007, 04:00 PM   #9
But for depth of field, is it for all effects, basically the same as a 1/3" as it's closer to 1/3" than to 1/2"?
Michael Maier is offline   Reply
