#16 |
Yes, I noticed the HV20 clips there late last week. A bit disapointing that they're all shot in the club, but at least the girl looks good.
Personal Website: http://www.avene.org |
#17 |
I'm confused with the HV20 clip that is in 1080p. HV20 is capable of 1080i, correct? Or does Canon deinterlaced the clip and post them as 1080p?
#18 |
It DOES shoot at 1080P, and 1080i.
#19 | |
-gb- |
#20 |
#21 |
Go to Menu > Rec / In Setup > HD Standard > HDV(PF24). See page 38 of the operator's manual.
That's what toggles between 1080i60 and 1080p24 in this camcorder. Hope this helps, |
#22 | |
"HDV(PF24): High-definition video at 1080i specifications for recording with a progressive frame rate of 24fps." Does that mean if I record in HDV24p, I can drop it to a HDV30p timeline to do editing? Or do I need to do the pulldown removal then edit in a HDV24p timeline? Thanks Taky |
#23 |
There's a process you have to do to get the 24p out of the HV20. There's a bunch of threads on the topic, mostly involving either After Effects or Cinema Tools.
"Babs Do or Babs Do not, there is no try." - Zack Birlew www.BabsDoProductions.com |
#24 |
Got the HV20
In followup to the above, which I posted a while back, I ultimately bought the Canon HV20, which has the accessory shoe and mike input.
#25 | |
The SD and 720 looked perfect. The 1080 was crystal clear but a bit jerky in places- the more motion the more jerkiness. I presume that jerkiness wasn't in the video but was because my PC isn't powerful enough to show it without skipping frames? I have a Dell with Intel Core 6400 (2.13 GHz)- 2 gigs of ram, a Dell 24" flat screen monitor which has a native res of 1920X1200. The video card is an NVIDIA GeForce 7900 with 256 MB onboard ram. OS is Vista Ultimate. What I'm concerned about is- when I record 1080i with the HV-20 and try editing it- will that jerkiness make it difficult to edit? Thanks, Joe |
#26 |
HG10 1080p30 footage?
Hey all,
The HG10 sample footage on this Canon USA seethedifference page looks very good to me, but I have a question about it. (I am a new owner of the camera trying to learn how to get the best possible results from it.) http://downloads.canon.com/seethedif...1080-movie.mov http://downloads.canon.com/seethedif...x720-movie.mov At about 4:10 in the clip, a graphic comes up saying "HG10 24p Cinema mode", which I assume means that the footage prior to that was shot in 60i and then deinterlaced (since Apple Compressor tells me that these clips are progressive). Notice that the Canon sample clips have a striking lack of interlace artifacts (i.e., venetian blinds and stairstepping) compared to 60i footage right out of the camera, e.g., see clips posted in this thread: http://www.dvinfo.net/conf/showthread.php?t=101059 -- i.e., any of the 60i clips in http://file.meyersproduction.com/hg10/.) When I try deinterlacing my HG10 60i footage in Compressor using its "spare-no-expense" settings (Resize Filter: Best, Output fields: Progressive, Deinterlace: Best - for the Apple users among you) the results are not nearly as good, not to mention that it takes forever. (I realize that the results depend on the type and amount of motion in the clip; as I compare my results to Canon USA's, I am taking that into account and limiting the comparison to footage with similar content and motion.) So my question is, to you HG10/HV20 owners, if you are able to get 1080/30p results you feel are comparable to (or better than) the Canon samples, what is your workflow? FYI: I am able to get comparable results to Canon's 24p Cinema mode footage by shooting 24p and using Apple's "1080p24 workflow for the Canon HV20 Camcorder". So my question is specifically about 1080p30 workflow. Thanks! |
