Editing for 1920x1080 vs. 1440x1080 at DVinfo.net
Old October 29th, 2006, 01:03 PM   #1
So The Canon HV10 captures 1920x1080. -and a belieave at this time its the first HDV camera avaiable yet to do so. The rest of the batch capture 1440x1080.
As far as editing this goes: Im worried about support for 1920x1080.
Premiere pro 2 shows its HDV settings at 1440x1080. If I capture using this HV10 cam to Premieres HDV timeline - will i be loosing resolution?
How can I be sure to capture and edit at 1920x1080?
Tyson X
Tyson Persall is offline   Reply With Quote
Old October 29th, 2006, 01:40 PM   #2
In premiere pro 2 you can customise the size by going to
new project>custom settings
instead of picking the hdv default
good luck
Stick Tully is offline   Reply With Quote
Old October 29th, 2006, 02:29 PM   #3
Stick,
The Adobe HDV settings are fixed on 1080x1440 and cannot be changed.
Perhaps you are thinking of the Adobe SDI-HD tab which is is 1920x1080.
Tyson X
Old October 29th, 2006, 03:14 PM   #4
So is the cam actually outputting 1980x1080? I thought it had to be 1440x1080 to meet the HDV spec.
Damnit Jim, I'm a film maker not a sysytems tech.
Ken Hodson is offline   Reply With Quote
Old October 29th, 2006, 04:15 PM   #5
The CMOS image sensor in the HV10 is 1920x1080. What goes to tape is HDV, which is 1440x1080.
Old October 29th, 2006, 05:59 PM   #6
Originally Posted by Tyson Persall
Stick,
check this screenshot, you can change the size
www.tullyvision.net/mess/pp2.jpg
i have an fx1 and if i put footage into after effects i have to change the aspect ratio to square pixels and make the comp 1920x1080, im not sure why though
Old October 29th, 2006, 07:16 PM   #7
Agreeing. This is what we also discussed in the Avid Liquid board. 1440x1080 out.
George Ellis is offline   Reply With Quote
Old October 30th, 2006, 11:33 AM   #8
Stick,
I never even thought to try Desktop Editing mode. Anybody know what they mean by "desktop mode"?
Yeah, I do a lot of after effects compositing. I will try this method.
So the output is 1440x1080 to tape. got it.
Again there i go reading the little advertising sticker on the camera and not the fine print.
Tyson X
Old October 30th, 2006, 04:40 PM   #9
Warning!
If you use your HDV footage with After Effects and capture with FCP - watchout as the footage needs to have it header re-written to 1440*1080 (from 1920*1080) as you lose half the horizontal resolution.
I am not sure if I have explained this clearly but if you do use this combination I can perhaps put a little more effort into explaining if you like !
Stick,
Lee Wilson is offline   Reply With Quote
Old October 30th, 2006, 04:44 PM   #10
Originally Posted by Lee Wilson
Warning!
what do u mean by header re written?
i capture in premiere pro2 then if i put the video into a comp in a.e the image looks shrunk so i change the comp to square pixels and 1920x1080
this hasnt caused me any problems so far... i usually end up rendering out the square pixeled footage from a.e and import it into a normal hdv premiere project and it looks fine to me
or am i missing something?
Old October 30th, 2006, 05:16 PM   #11
It is only a problem with HDV/FCP >> AE (as far a I know)
No.
