hd10u and "61883 class bus device" problem "no video" at DVinfo.net
Old September 28th, 2006, 03:50 PM   #1
Hi Folks,
I tried using my hd10u cam on my laptop. When I plugged the cam into the firewire port it installed without issue. But when I tried to view a live feed with dvrack or DVIO it either showed no video feed, or showed in dvrack a partial feed and then froze. I looked for the problem and came up with a "61883 class bus device" error in device manager. The error only shows up when I plug in the camera. I believe the 61883 error has something to do with the firewire bus, but I am not certain. I am using a p4 acer with xp and 1gig ram. Has anyone dealt with this problem, and if so how did you fix the issue? Thanks
Dwight
Dwight Flynn is offline   Reply With Quote
Old September 28th, 2006, 08:23 PM   #2
Are you using it in DV firewire mode ("DV locked"), or in HDV mode?
If in HDV mode, are you using WinXP SP2?
Does it show up in windows Device Manager under Imaging as a DV camcorder, or under Sound/Video controllers as AV/C tape device?
I don't have DVRack or others so not sure how well they integrate w/ HDV firewire stream, but there are some issues capturing (tape) in other software..
Colin Gould is offline   Reply With Quote
Old September 30th, 2006, 07:46 PM   #3
First of all this is the wrong forum. You want to post in JVC HD1/10. This is the Canon HV10. Yes I know that the marketing people apparently have a love for brand confussion.
Are you using the HDV add-on for DVrack?
Does you laptop video card support HDVrack?
I had a Acer laptop with a Sis chipset and it was a no go with HDVrack. Although with a little more time I think it could have worked. It could be as simple as that.
Damnit Jim, I'm a film maker not a sysytems tech.
Ken Hodson is offline   Reply
