Using HV10 as a deck at DVinfo.net
Old August 2nd, 2006, 10:02 AM   #1
From Canon USA site:
http://www.usa.canon.com/consumer/co...&modelid=14059
Concerning using the new camera as a deck:
http://www.usa.canon.com/consumer/co...14059&pageno=9
"You can share and edit your video easily by connecting your HV10 to your computer through the camcorder's USB 2.0 Full Speed terminal with the supplied USB cable. Once you're hooked up, DV streaming and ultra-fast transfer of movies and photos is a breeze. And because the HV10 uses the Firewire IEEE 1394 protocol, there's no loss of picture or audio quality in the process. You'll want to share your brilliant HD memories with friends and family, and the HV10 makes it fast and easy."
So, since this camera uses USB with "Firewire IEEE 1394 protocol" can the camera actually be used as a deck with NLE software such as Vegas?
I ask this since I believe that Vegas will want to see the camera on a Firewire port.
Dan Keaton
Augusta Georgia
Old August 2nd, 2006, 10:13 AM   #2
The HV10 is equipped with both FireWire and USB jacks. You'll probably want to choose the FireWire jack when using this camcorder as a deck. The FireWire jack is located on the camcorder's lower front, and the USB jack is on the back. See the attached images -- note the tiny little component video output jack on the front, just above the FireWire port.
Old August 2nd, 2006, 11:03 AM   #3
Dear Chris,
Thank you for the clarification.
This seems to be an interesting camera.
Chris, can you report if there is a microphone jack and/or a headphone jack?
Dan
Dan Keaton
Augusta Georgia
Old August 2nd, 2006, 11:11 AM   #4
Sorry, there is neither a microphone input jack nor a dedicated headphone jack. Most likely the yellow AV in/out jack can be assigned for headphone output, as offered on other Canon camcorders.
Old August 2nd, 2006, 12:45 PM   #5
THANKS A LOT, Chris, you are doing a fantastic job.
While we are at questions : i do not really understand what video output interface this cam has. They are mentioning DC100 ?? Neither S, nor YUV component nor DVI nor HDMI ??
Pierre Barberis is offline   Reply With Quote
Old August 3rd, 2006, 01:52 PM   #6
Hi Pierre, please see http://www.hdvinfo.net/articles/canon/hv10images.php
I've added some photos which show all of the input / output connectors.
For video there is analog AV in/out, DV/HDV in/out, and analog component out.
I don't know how anyone could squeeze DVI or HDMI onto this little thing.
Old August 6th, 2006, 03:42 PM   #7
Analog in hd/or sd
Hi Chris:
is there any confirmation if the analog in supports componant, and also if you can record in HD or are you limited so SD only, and in camera to analog componant output does the signal simply pass in the full 1920 mode or is it down converted and then up converted?
Sharyn
Sharyn Ferrick is offline   Reply With Quote
Old August 6th, 2006, 03:56 PM   #8
Good questions, Sharyn, and I'll try to get them answered via my contacts at Canon USA once the business week starts.
Old August 6th, 2006, 05:09 PM   #9
Just wonder if HV10 has S-video IN/OUT to convert analog Hi8 IN from another camcorder player to typical DV out?
Terje Hanssen is offline   Reply With Quote
Old August 10th, 2006, 12:08 AM   #10
So Chris
any more information re deck mode, recording HDV via the inputs, Component in etc?
Sharyn
