Small Legria cam to match G25 and XA20 as a C cam
Does anyone use a small Legria camcorder that matches the look of the G25 and the XA20 (more or less)?
I'm looking for a camera that is cheap, reasonably good in low light, has a reasonably wide lens and has a few manual controls. The camera will be used as a locked off camera getting a wide general plan in events and weddings. Thanks |
Re: Small Legria cam to match G25 and XA20 as a C cam
Hi Andrew
I use a Canon HF200. I cannot say how similar to the XA20 it might be, but I am impressed with the degree of manual control. It has manual mic levels, adjustable sharpening, adjustable exposure and focus as well as an accessory shoe for an external mic (proprietary) and and external mic port for something like a Rode. It also has an adjustable zoom speed from a really nice glacial creep to the usual "vomit" setting. I have been very pleased with it, even though it is just my "holiday" camera. I also have a Century Optics 37mm 0.65 WA attachment on it.
Cheers Tim Last edited by Tim Lewis; October 1st, 2013 at 06:27 PM. |
#3 | |
Thanks steve. I've heard the wide angle is not great and is restrictive. Is that the case? I ask as it's principle gob would be a locked off wide angle shot
#5 |
Its not bad but when I need it extra wide I use a raynox hd 58mm wide angle lens on it and its awesome..
#6 |
Thanks again.
#7 |
A pana DMC-FZ200? Jeff Harper who owns a xa20 as well claims it outperforms his xa20 at full zoom as it's sharper so that might be a cheap c cam alternative.: http://www.dvinfo.net/forum/wedding-...eddings-2.html
#8 |
Noa, I used it last night and it does outperform the XA20 at full zoom, noticeably sharper. Personally, I would not buy anything else for use as a b cam. For the price it is remarkable.
#9 |
Could it be that you posted a xa20/fz200 comparison shot in a church that showed the difference in sharpness? I remember seeing such a shot. I currently have a gh3/g6 but have not used them during a ceremony as I use handicams there for their ease of use, dslr type of cameras still scare me when it comes to continuous multicam "you only get one chance" type of recordings (as a solo shooter). Does the fz200 also has that 30 minute limit, meaning, do you manually have to press the record button again after 30 minutes?
#10 |
The panasonic looks interesting but it's 430€ here. Seems a lot. How does it do in low light?
I'm really looking for something around 300-350€ that can handle churches, has decent wide angle and will mix well with a canon xa20, g25 and canon dslr. |
#11 |
At that price your choice is limited, probably the cheapest Canon handicam you can find would be the safest bet since you are already using Canon camera's.
#12 |
yeah, the canon hf m506 is only 300€ but it doesn't have much of a wide end and if i have to buy a wide adaptor it just pushes up the price!
#13 |
Yes but if you need it then get it!! The 506 or hfm56 match identical that's what I use with my hfg25 g10, I have told you in my last post. Just get the hd raynox wide angle lens 58mm with a step ring. sorted..
