Vixia HF S100 at DVinfo.net
Old May 25th, 2012, 07:17 AM   #1
Vixia HF S100
Has anyone shot with this camera using a SanDisk Extreme 64 GB class 10 card? How did it perform for you? Thanks!
Evan
Evan Graham is offline   Reply With Quote
Old May 25th, 2012, 11:03 AM   #2
Re: Vixia HF S100
The card is above specs needed for the camera, it will work very well. Can't go wrong with SanDisk Extreme, I use them in all my cameras including the XA10. Not sure if your camera accepts 64GB cards, but as long as it does, you'll be fine.
Old May 26th, 2012, 08:35 AM   #3
Re: Vixia HF S100
Thanks Jeff. I've emailed Canon with this inquiry. I'll post up the results, as it seems to me there may be many others with this question.
Evan
Old May 26th, 2012, 10:52 AM   #4
Re: Vixia HF S100
The HF S10/100 is documented as accepting SD and SDHC cards. SDHC is limited to 32 GB max.
The 64 GB cards would likely be SDXC, and the S100 manual does NOT document support for SDXC (over 32 GB) cards.
Not clear what would happen if you tried to use a SDXC card in it.
dpalomaki@dspalomaki.com
Old May 26th, 2012, 11:09 AM   #5
Re: Vixia HF S100
Ebvan your manual will certainly list the card capacities that are accepted by the camera.
Old May 27th, 2012, 07:38 AM   #6
Re: Vixia HF S100
You're right about that, Don. I checked the manual for compatible cards, and it will only support SDHC cards, and that appears to be limited to 32 GB. Thanks for the input.
Evan
