Vixia HF M32 vs. Mac OS X at DVinfo.net
Old January 3rd, 2011, 08:18 PM   #1
I'm a wildlife videographer and currently use an iMac with FInal Cut Pro to do all my post production. I have a Canon XL-h1 and just recently picked up a Vixia HF M32 for when I cannot lug around the h1. I shot some test video the other day and went to Log & Capture it via Final CUt and could not get the application to recognize the camcorder. I then googled "Vixia and mac compatibility" and started to feel sick to my stomach after reading all the horror stories of what a pain it is to transfer the data from a Vixia to a mac.
Are there any solutions?
Brian Kleinman
Brian Kleinman is offline   Reply With Quote
Old January 3rd, 2011, 10:02 PM   #2
I'd just record directly to SD cards and then you can just pull the card out and transfer the files using any SD card reader. I'm on PC and a Vixia HF10 and find it is much slower to transfer from the camera to computer than an SD card. I initially liked the ideal of having built in memory, and I guess it would still be nice to have in case of emergency, but very quickly I found myself avoiding its use.
Pete Bauer
Old January 4th, 2011, 12:01 PM   #3
Thanks Pete for you input,
Yeah I agree this is becoming a headache. I did some research and found that you need a program to convert the AVCHD into a workable FCP codec ~ Roxio Toast was one of the applications, I'll probably give that a try.
Brian
Old January 4th, 2011, 12:06 PM   #4
HF and FCP
I don't have the new Vixia M, but mine is its 'granddaddy', the HF-100.
Connecting a camera to the USB requires selecting "PC/Printer" from the screen. That is the only way camera will properly show up on that Mac. One other thing: Log and Capture only works for camcorders that require capturing video in real time (i.e. tape-based DV or HDV, meaning those hooked up via FireWire). Tapeless media is ingested into FCP using 'Log and Transfer' feature. Final Cut should automatically see your camcorder when you select Log & Transfer.
Rather than editing AVCHD video directly (which is a colossal pain, even on fastest computers today), FCP will transcode it into a format that is much more manageable. This is normally Apple's ProRes 422, although if you wish, you can choose AIC (Apple Intermediate Codec). Both of these will take much more disk space than the original AVCHD files, but the result will be significantly lower rate of compression, thus allowing your Mac to work much less to decompress the video in real time while editing.
While I agree that it is easier to just stick that SDHC (SDXC) card into the SD slot on that iMac (or MacBook Pro), there is no need to avoid the USB solution. It is a bit clunkier (and perhaps somewhat slower), but it works perfectly fine.
Predrag Vasic is offline   Reply
