Water housing for the HF S20! at DVinfo.net
Old July 14th, 2010, 06:59 PM   #1
Can anyone recommend a decent water proof/housing for the HF S20, i will NOT be diving with it but i will be shooting in the rain with it for a few takes, i can spend about 450.00 bucks max, thanks in advance.
Ivan Martinez is offline   Reply With Quote
Old July 15th, 2010, 09:58 PM   #2
If you're not actually going in the water I'd try something like this:
http://www.bhphotovideo.com/c/product/550348-REG/Kata_KT_VA_801_17_CRC_17_Compact_Rain_Cover.html
Then get an assistant to hold an umbrella over you or mount it to your tripod somehow - because if you're getting soaked yourself, the camera is gonna end up getting wet too from touching it.
John Wiley is offline   Reply With Quote
Old July 16th, 2010, 01:19 PM   #3
John thank you soooo much, that will work perfect for what i am doing.
Old August 15th, 2010, 04:18 PM   #4
Ikelite
I use it all the time with my HFS100...works great!
Best, Craig
Craig Hollenback is offline   Reply
