New HF-S21, First Impressions - Page 2 at DVinfo.net
Old August 4th, 2010, 11:49 AM   #16
The Instruction Manual for the Canon HF-S21, HF-S20, and HF-S200 is located here:
http://downloads.canon.com/cpr/softw...ion_Manual.pdf
For setting shutter & aperture, look at pages 71 & 72
Bill Koehler is offline   Reply With Quote
Old August 23rd, 2010, 08:20 AM   #17
Yes, I wish I had waited for this model for the native 24p in particular. Good overview! Just one question - what is the cute little matte box you have attached, and would that work with the WD-H58 converter? I posted earlier on this, but no one has picked up on it yet.
Terence
Terence Morris is offline   Reply With Quote
Old August 25th, 2010, 01:08 AM   #18
HF-S21 Questions and First Impressions
Hi Terence:
Like you said in your post..... It is time for Art & Crafts. I also have been looking for a solution for the wide angle and the lens shade. so I adapted an old Hasselblad bellows lens shade that was used with their lenses, this thing is probably 15-20 years old. but is in perfect condition, You can adjust the bellows so that there is no vignetting or cut off of light reaching the the coverage of the lens.
Luis
Luis A. Diaz is offline   Reply With Quote
Old August 25th, 2010, 08:22 AM   #19
Thanks for the reply, Luis. I should check out some second hand camera shops in case I can adapt something similar.
Cheers,
Terence
Old September 1st, 2010, 03:54 PM   #20
Originally Posted by Ove Christoffersen View Post
Thanks to Jacob, Louis and Robin for the fast answers – my second question about aperture change – Jacob says no but Louis is a bit in doubt – I would appreciate if you would look into the matter and try one or both of the things you mention – touch screen or wheel – if a smart way of doing it is possible – look forward if any solutions is available
Don't know if it's too late, but...
Just picked up an S200. You can indeed change aperture, speed, exposure while recording. You can assign any ONE of them to the custom dial, or change from the touchscreen.
Tom Majeski is offline   Reply With Quote
Old September 1st, 2010, 09:57 PM   #21
Hi Tom:
No you are not too late. I finally experienced the two modes to change the aperture and shutter speed while shooting and you are right they both work. I don't usually used it but I can see that it could be a plus sometimes with planned shots.
I think that Ove, a few posts back wanted to know if it could be done.
Luis
