Lens hood for HV30 at DVinfo.net
Old December 31st, 2009, 09:32 AM   #1
Lens hood for HV30
Can anyone verify that the following lens hood works with the HV30?
Amazon.com: Lens Hood 43mm: Electronics
Old December 31st, 2009, 01:50 PM   #2
You got me searching for it on Amazon over here - no joy, but I did find these:
Camcorder-Gegenlichtblende Enjoyyourcamera DV-s 43mm kaufen im Enjoyyourcamera.com Shop
and
Camcorder-Gegenlichtblende Enjoyyourcamera DV-b 43mm kaufen im Enjoyyourcamera.com Shop
These look interesting too.
I had never heard of this store so caveat emptor. Here's their contact page:
Fotozubehör und Kamerazubehör im Versandhaus Enjoyyourcamera.com - Kontakt
Old December 31st, 2009, 07:22 PM   #3
As I'm sure you read, there are a couple who bought and used it with good results, but one person says it interferes with the sensor...looks great though, what a nice looking low cost solution.
Old January 2nd, 2010, 03:36 AM   #4
I use the Canon XH1 lens hood together with my Raynox 6600 Pro. It fits very well - just push it on. The downside is that it will block the i.AF so you have to set it to AF instead. But I think that is the same for all wider lens hoods...
Hans Sandstrom is offline   Reply With Quote
Old January 2nd, 2010, 12:59 PM   #5
Any lens adapter attached to the front will block the iAF sensor. I turned it off using regular AF anyway. Not much difference.
I believe I'm the first one who came up the idea using the XH-A1 hood on Canon WD-H43 WA lens back in 2007. Since Raynox 6600 has the same front size, the lens hood fit on it too.
Lens Hood for WD-H43 and Raynox 6600 on HV30 | L.A. Color Blog
LA Color Pros Blog
Old January 2nd, 2010, 05:20 PM   #6
Certainly works with HV20. I feel it's worth its weight in gold for what it does to make the little camera look more "pro." Kind of like a Sony HC1.
Nate Haustein PXW-FX9 / FCPX
www.flightcreativemedia.com
Nate Haustein is offline   Reply With Quote
Old January 3rd, 2010, 11:09 AM   #7
Works well with HV40 - filed down right edge slightly with a rat tail file, no interference with IF.
IF works slightly better if you shoot 24p. (24f, whatever).
Steve Rosen is offline   Reply With Quote
Old January 4th, 2010, 05:07 PM   #8
Jeff,
That's the one I bought off ebay. No problems.
Ross
Ross Hunter is offline   Reply With Quote
Old January 5th, 2010, 10:20 AM   #9
Thanks guys...I'll order one!
