Rode Video Mic
The Rode Stereo mic i have fits perfectly in my HV30s accessory shoe, now i am thinking of getting a Rode Video mic as an alternative for certain filming.But i read somewhere that the Video mic will not fit or rather slde in the HVs accessory shoe, does anyone know if this is true as according to its spec it has a standard shoe fitting.
It fits fine.
Thanks Rikki another point if you have a RVM you will know the VM is 8.84" will it be ok with the canon wide angle on, i ask because the muff on my RODE STEREO had to be trimmed on a sony cam i had to stop hairs showing, the RS is 7" but looks like Tthe shoe fitting is farther forward on the VM, the RS does not cause problems on my HV30 with the wide angle lens on.Martyn
Well i got mine today it does fit but not as easily as the RS external etc, anyway it does not matter mine is going strait back far more motor hum picked up than by the RS, strange from a directional mic.
#5 |
Hi Martyn, probably too late if you've returned the VM, but you were feeding too much audio level from the VM into your HV30. That's why you heard the motor hum and I'd guess you were on auto in a quiet room.
In the battery compartment of new Rode Videomics there are 3 sets of dipswitches so you can set the output level to, 0, -10 and -20db. The VM is shipped with them set to 0db output which is too loud for the HV30. Set them to the -10db setting, then adjust the HV30s level on manual, for speech from about 3 feet out ahead of the VM on the cam. Then you won't hear the motor hum. You'd only set it to -20db when there's giant audio happening like Formula One car races etc. This comes up a lot, RODE are looking at shipping the VM set to -10db. Cheers.
Drink more tap water. On admission at Sydney hospitals more than 5% of day patients are de-hydrated. |
#6 | |
