Hind Sight is 20/20 - Page 2 at DVinfo.net
Old August 13th, 2009, 09:36 AM   #16
When I first got my HF-S100 I was shooting in manual mode all the time. My last camera was a DVX100. But then I noticed I got better results by just shooting in auto. And the image is fine. The only situation I use manual for is low light. The HF-200 reportedly does a little better in low light. For my purposes, I shoot 60i always. I can deinterlace later for progressive.
David Merrill is offline   Reply With Quote
Old August 13th, 2009, 09:41 AM   #17
Yes, back in the day of the first 3 CCD cameras, we buy the camera, leave it on manual and never look back. Auto was garbage back then.
So that's what I did with this camera. Apparently maybe its so good with face detection and etc... that auto will be the best. I'll tinker with ALL the settings and test shoot this weekend.
I did have it on Programed Auto Exposure in manual, which should be the same as for auto though, but let's see if there is a real difference.
Ronald Lee is offline   Reply With Quote
Old August 13th, 2009, 10:04 AM   #18
I don't think most of the consumer camcorders are going to do well in low light. What I found worked best for low light situations with my HF-S100 was Tv mode 1/30th and put on a tripod. Also I limit the gain to 6 which cuts down the noise. Even then I get some noise in darker areas. I then use Neat Video to eliminate any remaining noise. I haven't had the camera very long though. I keep experimenting.
Old August 13th, 2009, 11:36 PM   #19
Originally Posted by Ronald Ng View Post
Bingo, you need to know what you are doing with your camera.
I think you may have misunderstood. I am not concerned with the image my camera is producing. I love that. My concern was with the available methods of delivery.
"Get Er Done!!!"
G. Lee Gordon is offline   Reply With Quote
Old August 14th, 2009, 05:12 PM   #20
You got that answered, right? You've got HD and you can output to SD DVD also.
Old August 19th, 2009, 07:59 AM   #21
I think you are confuse about the delivery and not the format.
to deliver something in HD to a channel it will be on a tape like HDcam or even a HDV tape works...
if you cannot record your final on tape you can also give a DVD data with full res quicktime in it
A dvd video is a mpeg2 compression (and sd) that is not what channels use.
The cheap and simplest way is find a camcorder that can record back from your computer to a HDV tape you are in HD on a broadcast format
cheers
Olivier Jezequel is offline   Reply
