Irv Design Manual Focus Ring - DO NOT LUBRICATE!! at DVinfo.net
Old June 23rd, 2009, 04:49 AM   #1
Love Irv's invention for my HV20.
BUT NOTE: If you're sick of the squeeking / noise... whatever you do, do not spray lubricant (like I did...)
It runs off a rubber ring that drives the shaft as you turn the ring, if you lubricate it it'll start free turning and wont work anymore. And there's no easy fix.
Just a word of warning.
Josh Fung is offline   Reply With Quote
Old June 23rd, 2009, 05:42 AM   #2
thank you Josh - I was wondering about that - just about to reach for the graphite grease!
Cheers - Paul M.
www.perbenyik.com
Old June 23rd, 2009, 08:22 AM   #3
If you go to the hv20 forums there some discussion about this, and some advice about what lubricant to use, and where to apply it.
Richard
Richard Hunter is offline   Reply With Quote
Old June 26th, 2009, 09:12 AM   #4
mounting placement?
IRV just contacted me re placement
pin should be at 4 o'clock
confusion for me was in his video it is at 8 o'clock
he wrote that it was because of the mirror which was used
Stuart Kiehl is offline   Reply
