#16 | |||||
Initially I bought the Canon HG21 to see how it would compare with the HV20/30 that I had used for small budget shoots where I have to be a one-man-army. I was quite nervous about using the camera until I brought the video into the editor, and was happily surprised at the increase in quality. Overall color balance was better. No more macro-blocking on fast moving subjects, or dimly lit subjects. Better quality audio, provided you were feeding a strong audio signal from a good pre-amp / mic combo. ( I use a Sound-Devices MixPre powering AudioTechnica 4053a hypercardiod mics, Sennhseiser G2 UHF systems using Sanken Cos-11x lavs or Tram-50 lavs if the environment is noisy ) Quote:
...But the MPEG4 compression that the AVCCAM and AVCHD cameras use to store video images are essentially the same. Quote:
I never said that tape was unusable, but the world is rapidly going all-digital, and from my own experience this is a very good thing. I will still shoot tape if the client asks for it, but for any future projects I will try to avoid tape when ever possible. |
#17 |
I also switched from the HV20 to the HG20, but when it comes to your original question: "Is there any reason not to buy the HV30 for a MiniDV tape solution," I have to say "no." The main difference between the HV20 and HV30 is that the HV30 has 30p mode.
I had two HV20s and if it wasn't for problems with tape dropouts, I would swear by that camera - problems that are just simply part and parcel of the MiniDV format.
Equip: Panny GH1, Canon HG20, Juicedlink, AT897, Sennh. EW/GW100, Zoom H2, Vegas 8.1 |
#18 | |
We have three JVC 250's and all have recorded without incident. I guess everyone's mileage varies.
Michael Rosenberger Sure I'll shoot your wedding, for two million dollars. |
#19 | ||
Ultimately, I think if you look higher up the professional tree you will find that most productions are shot on tape. HDCAM, Digibeta, DVCAM and HDV being the most popular formats. If tape really had as many issues as you are leading us to beleive, I think the top end of the market is where you would see a change to solid state as the work at that level is more critical but this has not happened. Tape is still a safe bet, is robust, archives well, has easier workflows and will be with us for many many years. I don't think you need to worry about the world moving off tape and being left with nothing to play your HDV or DV tapes on as one user suggested. VHS has been dead for many years and yet I can still get DV decks with VHS recorder built in and DVD recorders with VHS recorders built in. HDV is not going to just dissapear. I think if you are only going to have one camera for your 'professional' production that HDV (tape) is the best way to go at this point in time (at the lower budget/domestic end). You can shoot HD (HDV) or SD (DV) and it just gives you more options to source income. I work in many TV Studios in the UK and most of them have the facility to play HDV or DV. If I was given a DVD with AVCHD or another disc based format, I would reject it as it is too difficult to work with. Last edited by Tony Sal; May 6th, 2009 at 06:48 AM. |
#20 | |||||
#21 |
Coming in a bit late here. But I, too, am not fully ready to declare the uselessness of tape and its demise. We have had our butts saved because of file corruption on our Focus DTE (the Firestore Hard Drive specific to the JVC GY-HD). Although we use the Focus DTE as our primary capture medium, the tape provides both a backup and our primary archive medium.
To those who may consider AVCHD format of the Vixia HG cameras somehow better, that's still debatable, but "handing over a file" to an editor is not the quick and dirty method some may suspect it is. The AVCHD transcoding when going to a NLE platform, I've found is often slower than real time meaning it's slower than transferring tape. Regardless, you must consider this in your workflow before deciding to go with AVCHD cameras. Still, I use an HG21 and am impressed with its image for Web based delivery. I still haven't optimized for use for DVD delivery. I suspect that for DVD, I should be shooting exclusively in 24P regardless of the "look" I'm pursuing. I keep hearing I will get less stuttering. Tests continue. Final word: Consider all the aspects of workflow from capture to edit to archive before praising or poo-pooing a capture medium. Dave |
