GL2 Wa adapter and HFS 100? at DVinfo.net
Old April 19th, 2009, 07:21 PM   #1
Has anyone tried the GL2 58mm screw on WA adapter on a HFS100? It's less than half the price of the Canon WA adapter for the HFs100.
Thanks, Craig
Craig Hollenback is offline   Reply With Quote
Old April 21st, 2009, 03:58 PM   #2
It's on order
I took a chance that it will work and ordered it. I'll post results on Friday.
Best, Craig
Old April 22nd, 2009, 05:14 PM   #3
Hi Craig,
I use a Canon WD58 on an HV30, which has a 43mm diameter. With a step-up ring it works fine. I'm not sure that its zoom-through though - I only use it for wide back up angles.
Best, Craig
Joel Peregrine is offline   Reply With Quote
Old April 27th, 2009, 07:04 PM   #4
Works great!
I have attached the WA adapter designed for the GL2 on my HFS 100 via the 58mm thread. Works great. It also allows for a polarizer to get placed in line. No vignetting. Much less in cost than the Canon WA for the 100 and the picture is very good as well.
