Hv30/HG21/hfs10 at DVinfo.net
Old March 23rd, 2009, 10:26 AM   #1
Hv30/HG21/hfs10
I'm in the process of selling my XL2 and looking for something a bit smaller. I think I've narrowed it down to either the HV30, HG21 or the new hfs10. My initial thought is to wait for the new HFs10. I don't mind spending the money, however I would be really be discouraged if I paid double and the quality difference wasn't there. I've seen some samples from the HV30 that have been pretty impressive. I guess my biggest concern is the HDV vs MPEG4-AVC. What will yield the best results, clarity, lack of noise, color production? I understand that the HFS10 has way higher resolution, but how is that affected by compression. Maybe they have made leaps and bounds in compression, but I'm kinda old school and where I come from compression is not a good thing... Any ideas or advice would be great. I really like Canon, but how would these compare to the sony hdsr12?
Darrin McMillan is offline   Reply With Quote
Old March 23rd, 2009, 10:34 AM   #2
The difference between the HDV and AVCHD formats is not in image "quality" so much as recording options and workflow. Compression is pretty much a non-issue these days... *all* digital video is compressed. It's just a question of how efficient the compression is. The AVCHD codec is about twice as efficient in encoding as HDV. Regardless, I would say that you probably won't be able to detect any difference in image quality between any of these camcorders, HDV or AVCHD, when viewing them on an HDTV at normal viewing distance.
The decision is really between tape (HV series), hard drive (HG series) or flash memory (HF and HF S series). What you're getting with the more expensive HF S camcorders are certain features such as peaking, color bars, AGC limiter, focus wheel, etc. that aren't available on the other models. The HV series has a focus wheel, but not all of the other extras that the HF S series has.
Old March 23rd, 2009, 10:44 AM   #3
One point: the HG series can also record to flash memory.
Equip: Panny GH1, Canon HG20, Juicedlink, AT897, Sennh. EW/GW100, Zoom H2, Vegas 8.1
Brian Boyko is offline   Reply With Quote
Old March 23rd, 2009, 10:58 AM   #4
i have an HG21
and it is a fabulous camcorder! right now, I am cutting together a shoot with it
and my EX1, and it matches up quite nicely. You will NEED the bigger battery
pack if you go for that one, or any of the smaller cameras, the small one
lasts about 65 minutes.
Scott Hayes is offline   Reply With Quote
Old March 23rd, 2009, 12:30 PM   #5
Thank you so much
Thank you Chris and everybody else, as always great information. Still not exactly sure which way to go. Damn decisions.. decisions..
Thanks Again
Old March 23rd, 2009, 12:36 PM   #6
Purchase
Chris, not sure if you'll get this again, but if you were to buy one of these three which one would it be. Not that I don't value all recommendations. It was Chris that turned me onto my very first cam and actually my Xl2 as well. Anyway.. Cheers
Darrin
Old March 23rd, 2009, 12:53 PM   #7
No doubt about it, HF S10 or HF S100, easily. The AGC limiter and the focus / scroller wheel and other unique features are well worth the extra bucks. Skip the onboard flash and get the S100 if you don't want to pay as much, but frankly I like having dual memory; makes it easier to share media with friends.
If I had an XH series or XL H series camera then I'd pick an HV30 or HV40, since they're all tape-based HDV.
Old March 23rd, 2009, 01:54 PM   #8
Thanks again
Thanks Chris. That's what I was looking for. :)
Cheers
Darrin
Old March 24th, 2009, 06:39 AM   #9
Yeah, that is a pain - with the HV20 (and I'm assuming the HV30,) there are a few "won't blow up on you" third party battery packs for about half the price of the official Canon batteries. With the HG20/HG21/HF10/HF11/HF100 Canon introduced some sort of fancy schmancy something or other - basically, unless you get an official Canon battery:
A) It won't charge up in the camera, you have to buy a third-party charger.
B) It won't even give you a rough estimate as to how much battery power is left, meaning it'll shut off suddenly and without warning when the battery runs out of power. (Most of the third party batteries try to get around this by having a button you can press which lights up a bunch of LED lights)
On the plus side, the "official" Canon batteries will not only give you a battery power estimate but will tell you how much time you have on that battery straight down to the minute. But they're expensive as hell.
There's certain things you should just consider "part of the cost" of the camera. Things like a UV filter, which should remain on at all times to protect the lens, a hood, to prevent against lens flare caused by the UV filter (unless you're like me and think that lens flare actually looks kinda cool.) batteries, tapes (if you get a tape based camera) SD cards (if you don't), tripods, audio equipment...
Hmm... I think I may have solved the mystery of why I never seem to save any money every month.
(I kid, I make extra payments to my student loans instead of having a traditional savings account; when that's paid off in a year, I'll start saving more normally.)
Old March 27th, 2009, 07:39 AM   #10
Very true,
amazing camcorder, you will be downsizing comparing to XL2, but even SD downconverted video from HF S10/100 looks awesome, I'd say it's a GL2 in Canon's HD line, easily beats any camcorder of that size and price.
I love this place!
Old March 27th, 2009, 10:59 AM   #11
Originally Posted by Buba Kastorski View Post
Very true,
I thought the HF10/100 does not shoot SD video.
Herm Stork is offline   Reply With Quote
Old March 27th, 2009, 05:09 PM   #12
It doesn't, but all you have to do is just export to SD resolution to get SD video.
Old March 27th, 2009, 05:09 PM   #13
You are correct, none of the Canon AVCHD cameras record standard definition.
He's talking about downconverting to SD later in the post-production process.
Old March 27th, 2009, 07:50 PM   #14
Go Cycle
My HF S10 delivers better HD material than my HV-30. Very crisp picture plus I can adjust GAIN so that grain is kept to a minimum. I can't tell the difference between the 24 MPS or 17MPS settings. I do downconvert to SD and all I can say is WOW!
See my post: http://www.dvinfo.net/conf/avchd-for...ip-saving.html
Very true,
Lou Bruno
Lou Bruno is offline   Reply With Quote
Old April 19th, 2009, 07:14 PM   #15
HFS 100 and EX1
We had purchased a Hv30 and was pleased with the picture...it was close to our sony Z1U. We have been intercutting the Z1 U footage with our EX1 so the HV30 was an inexpensive third camera. For reasons unknown, the Hv30 began ejecting tapes when the slightest temperature change occured. We returned it and got a HFS 100, The image quality is very close to the EX1 in outdoor shooting. The file sizes are huge however compared to the EX1 via FCP. It does edit well in FCP with the EX1 footage. So far so good...only complaint is the cost of the Canon WA adapter. I wonder if the old 52 mm screw on adapter from the GL2 would work. Less than half the price.
Best, Craig Hollenback
Key West – Florida Keys - ConchTV - KeysTV
Craig Hollenback is offline   Reply
