HV30 as a Deck Question at DVinfo.net
Old April 29th, 2008, 09:23 PM   #1
I am planning on buying the HV30 for a deck. I have looked at the specs and do not see a firewire port on the HV30. Is there one? If not, how are you guys connecting to your computer?
Steve Gray is offline   Reply With Quote
Old April 29th, 2008, 10:15 PM   #2
There is a firewire port. It's covered near the battery compartment.
LA Color Pros Blog
Old April 29th, 2008, 10:20 PM   #3
It has FireWire Port
It has FireWire Port (=IE1394).
HV30 as a Deck Question-hv30-fw.tiff
Pedanes Bol is offline   Reply With Quote
Old April 29th, 2008, 10:28 PM   #4
It also has an HDMI port in the same area. A very nice feature and option for this level of camera.
Eric Darling is offline   Reply With Quote
Old April 29th, 2008, 10:40 PM   #5
See attached grab from owner's manual -- circle #13 -- click to see it big.
Old May 3rd, 2008, 11:44 AM   #6
does anyone know if i would get better quality from importing from the HDMI output rather than the HDV/DV firewire. Ide be using it as a deck also for my A1
Loren Simons
Loren Simons is offline   Reply With Quote
Old May 3rd, 2008, 01:37 PM   #7
Not better quality, necessarily, but a better codec. You'd need a way to digitize HDMI, which requires additional hardware, but it's inexpensive as video gear goes. BlackMagic makes the Intensity, which starts around $249 USD and goes in a desktop computer. Then, you get the choice to digitize to whatever codec you choose. This is beneficial when you need an I frame codec for use in effects or other compositions, where additional rendering passes will be involved. I frame codecs are also generally less demanding on the processor, freeing up cycles to handle other stuff.
Old May 6th, 2008, 11:53 AM   #8
No.
Once the images are on tape, they are stored as HDV. So you can't gain quality by extracting them in a different way.
Recording live is a different matter.
If you have a means of capturing 1080p images, you can bypass the tape/HDV stage completely.
Glyn Williams is offline   Reply With Quote
Old May 7th, 2008, 12:30 PM   #9
Go Cycle
You should have no problems. I use my HV-30 as a deck to my laptop in the field.
Lou Bruno
Lou Bruno is offline   Reply
