The only way I've figured out how to print to video at DVinfo.net
Old April 24th, 2008, 10:27 AM   #1
Okay, I know printing out to video with the HV20's 24p mode is impossible. But there is a way to print the video out strictly for archive purposes and/or festival submission that requires Mini-DV tape. Basically, you do all of your telecine stuff first, edit, and then export a video file at 29.97 instead of 23.98 or "Current". Then start a new project with all the default 1080i/60i presets, I'm using FCP by the way, and then print to video with the 30p file in the timeline. The video looks fine with no stutter, as far as I can tell, and it's all on tape with the 24p look. It'd be nice if it could be straight 23.98 but that's not an option apparently.
P.S. Sorry if this has been posted or is common knowledge. I figured this out myself just recently.
"Babs Do or Babs Do not, there is no try." - Zack Birlew
www.BabsDoProductions.com
Zack Birlew is offline   Reply With Quote
Old April 24th, 2008, 11:46 PM   #2
I discovered the same with Premiere Pro. First have to re-render the video with 3:2 pulldown inserted in After Effect. Then load the clip in a 60i timeline and Print to tape from there.
LA Color Pros Blog
Taky Cheung is offline   Reply
