time lapse vs the sun - Page 2 at DVinfo.net
Old April 15th, 2008, 06:00 AM   #16
Bert,
That's exactly what it is. It triggers the shutter at 'user defined' intervals for time lapse when the camcorder is set to photo mode.
On a separate note, but using similar logic - I connect a 6 ft fiber optic cable to the remote that came with the HV20 to capture nature closeups without scaring the critters off.
Loren Lewis is offline   Reply With Quote
Old April 15th, 2008, 12:51 PM   #17
I can't wait to see how yours come out.
My videos
http://www.youtube.com/user/lucasberg
Joey Atilano is offline   Reply With Quote
Old April 15th, 2008, 03:15 PM   #18
Well --
the good news is that I did get about 800 photos in sequence over a period of hours, so the intervalometer does work as advertised.
the bad news is that I haven't been able to draw them all into Vegas 7 and I'm not sure if it's a Vegas setting, or my pc doesn't have enough power or memory
(5 yr old Dell Pentium 4 - 2.8 ghz - 3 gb ram).
So you won't get to see any results until I figure out what the obstacle is.
Old April 15th, 2008, 03:56 PM   #19
Did you import them as an image sequence ? In Vegas click on the 1st picture in the folder then at the bottom check import image sequence or something then it asks what frame rate 12,15,24,or 30fps. It will bring them in as a video clip.
If you have any questions message me on Vimeo.
Joey AKA Lucasberg
My videos
Old April 15th, 2008, 04:14 PM   #20
I reduced the size of the images to 320x240 to see if that alleviated the problem loading into Vegas 7 and it did.
But each obstacle I fight through, has another right behind it.
On to the Vegas forums next with some questions!!!
Old April 15th, 2008, 04:32 PM   #21
I have used the camera and the FS-C (external recorder) to do time lapse and slow motion clips. You get the same resolution (as you would in the Photo Mode) if you use the camera in the HDV mode and using Premiere CS3 I have compressed the timeline by a factor of 100 and streached it by a factor of 10 (you can do any factor you choose). I use the time compression for cloud development and sunrise/sunset clips and the time streach (and 30P mode 1/2000 of a second shutter priority) for recording the aerodynamics of finches around my bird feeder. The FS-C 100GB model will record about 8 hours of HDV video from a camera in the standby mode (no tape being used, no head wear)
Terry Johnson is offline   Reply
