HV20 or HV30 and index marks? at DVinfo.net
Old April 2nd, 2008, 03:59 PM   #1
Can you search for index marks with these cameras?
Scott
Scott Shama is offline   Reply With Quote
Old April 3rd, 2008, 12:10 AM   #2
Scott
Scott, there is no reference to this in either manual. It appears that "zero set memory" is the nearest you'll get.
Old April 4th, 2008, 08:59 PM   #3
The Canons usually have "Date search", which will fast-scan back/fwd (w/ playback) looking for a date change, eg from the automatically-recorded "time of shooting" metadata in the stream. Close enough to index? (still pretty slow to fast-scan, but... works...) Note, normally only accessible on the remote control.
The HV10 has this, 20 & 30 should also, check the manual...
Colin Gould is offline   Reply With Quote
Old April 5th, 2008, 02:16 AM   #4
Right on, Colin. HV30 NTSC manual p32:
Locating Scenes by Recording Date
You can locate the change of the date/
time zone with the date search function.
Press or on the wireless
controller.
• Press more than once to search for
further date changes (up to 10 times).
• To cancel the search press .
NOTES
�� Recordings shorter than 1 minute per date/
time zone cannot be located with this function.
�� Date search may not function if the date, time
or data code are not correctly displayed.
�� If there are sections recorded in different
standards (HDV/DV) on the same tape, the date
search may not work correctly
Last edited by Colin McDonald; April 5th, 2008 at 02:18 AM. Reason: Added which model quoted
Colin McDonald is offline   Reply
