Thread Tools
Search this Thread
#16 |
Faster SD DVDs w/ DVD Recorder
Given that you can output HDV to the HV20, it would seem that you could bump out to tape through the HV20, then plug into a DVD Recorder set top box and record a DVD.
The DVD would be 720x480, 60i (with random interlaced frames) and not take advantage of widescreen tvs, but it would be a DVD good for faster review and not hoarding the computer with renders. Rip it apart with Mpeg Stream Clip 2 and you could add new menus to it in DVD SP (according to other posts...) without re-rendering the video & audio assets. Anyone done this yet? Any pitfalls? This seems pretty cool for bypassing all the Compressor renders and doing things real time (record, then playback). My thinking it is would be FASTER by a few hours of encoding. Best, Anthony Torres |
#17 | |
#18 |
What format are you editing in? Are you doing native HDV editing? ProRes422 editing? AIC?
#19 |
Just a quick update, the settings worked with my HV20 as well.
This makes life much easier for me, as I cut on a FCP, but my colleague use Premiere and he has the real work station. I was worried about transferring clips from FCP to Premiere, but now I can do some editing at home, print to tape and bring the tape over to his machine and capture there. PS Will I lose any quality in this process? |
#20 | |
#21 |
Settings
Yes, the settings are for editing native 60i HDV. The 24P is wrapped in 60i. You are NOT editing 24P. You are editing in a 60i timeline so you can record to tape (which is restricted to 60i). So there is NO reverse telecine going on. Which saves time and drive space for rough cuts.
Again, prior posts review the ups and downs of this approach. But you have to be native 60i HDV timeline to go back to Tape. You ARE recompressing all the frames to get the HDV to record to tape. This takes some time, which is why folks advocate transcoding to ProRes or another codec. Alas, with those codecs you can't record to tape. Only native 60i HDV works. So is this a generation down? Yes. If you were editing DV, your effects/transitions would render, but that's it. Alas, HDV from the HV20 is awesome, and you can do amazing things with Magic Bullet Looks and Conduit/Dv Matte Pro 3. In a sense, you should be running Magic Bullet looks. All the good looking stuff is more attributable to MB Looks. (without cc, a lot of action films look like junk. It's that color correction that gives it a pop. Magic Bullet Looks makes it easier for all of us.) 35mm adapters can wait, particularly when you could buy 2 HV20s for the price of one full kit (including 35mm lens). Shallow depth of field is great, but cc sells the shot. Good luck, Anthony Torres |
