HV20: 35mm equiv. of 10X zoom at DVinfo.net
Old January 9th, 2008, 06:45 PM   #1
I have recently ordered a Canon HV20 because of the high ratings it has, but to increase the zoom range, I have also ordered a Canon 1.7X lens extender. I am surprised that this is the only extender that Canon offers for this model, and that it has no front filter for either filters or a lens hood.
It is also difficult to find 35mm focal length equivalents for camcorder lenses.
e.g. What is the 35mm equivalent of the HV20 10X zoom?
With pro camcorders with interchangeable lenses, what lenses are available that are over 20X? e.g. What do wildlife photographers use?
Tony Markle is offline   Reply With Quote
Old January 9th, 2008, 06:51 PM   #2
43mm to 435 approx according to the manual.
Chris J. Barcellos
Old January 9th, 2008, 07:23 PM   #3
On a recent job, we rented two long lenses. I think they were 86x and 75x. http://www.canon.com/bctv/products/index_box.html You wouldn't want to use these for wildlife though--probably weigh about 50-80 lbs. You don't mount the lens to the camera--you support the lens and attach the camera to it!
Andy Tejral
Railroad Videographer
Andy Tejral is offline   Reply With Quote
Old January 9th, 2008, 07:41 PM   #4
Tony I've had good results with my extender for wildlife. The range isn't too shabby and the picture is fantastic. The biggest drawback of the extender is not the range but the amount of range; when you zoom back you see the sides of the lens about half way through so zooming out presents some problems.
Matt Buys is offline   Reply With Quote
Old January 10th, 2008, 12:32 PM   #5
Thanks. Not quite as long as I would like.
Tony
Old January 10th, 2008, 12:33 PM   #6
Thanks. Yes, those are something that a movie crew would probably use.
Tony
Old January 10th, 2008, 12:36 PM   #7
Thanks, Matt. Good to hear you get great quality with that combo. I guess with the 1.7X, that would give me the 35mm equivalent of about 740mm. I would still like more reach, so may try a 3X extender made by a different company some day.
I'm not too worried about vignetting in the lower range, since I would only be using the extender in the upper range.
Tony
Old January 10th, 2008, 09:11 PM   #8
Is there a 3x extender out there for the HV20? I would love to pick one up even if it's so-so quality.
Old January 10th, 2008, 10:44 PM   #9
Raynox makes one, but I don't know what the quality is like. My other concern would be how adapter rings would affect image quality, since you are increasing the distance between the extender and the front of your lens. With the Canon extender, that distance is fixed and designed specifically for a 43mm front thread.
Also, if I had to use an extender and adapter rings, I would want to be stepping down in size, not stepping up in size. Stepping up would cause even more vignetting.
http://www.bhphotovideo.com/c/produc...efinition.html
Tony
