Canon VIXIA HF10 and HF100 flash memory HD cams - Page 2 at DVinfo.net
Old January 7th, 2008, 10:55 AM   #16
It also appears it has better Lens and imaging sensors than the HV20/30
HF10
"Canon HD Video Lens with 12x optical zoom, a 3.3 MP Canon Full HD CMOS sensor,"
Is the only difference between the hf10 & the hf100 the memory card thing?
If so I might just be interested in the hf100 in the future
Ocean Zen is offline   Reply With Quote
Old January 7th, 2008, 10:57 AM   #17
Originally Posted by Ocean Zen View Post
Where did you read that?
From the official Canon USA specs for the HF10:
FXP (17 Mbps) 2 hours 5 min (to internal 16GB flash) -- allows 1920x1080 Full HD Recording
Old January 7th, 2008, 11:01 AM   #18
This is another 'trap'. More pixels don't necessarily make a better image, especially in the absense of good light.
Clips | Stills
Wes Vasher is offline   Reply With Quote
Old January 7th, 2008, 11:01 AM   #19
It also appears it has better imaging sensors than the HV20/30 HF10 "Canon HD Video Lens with 12x optical zoom, a 3.3 MP Canon Full HD CMOS sensor"
The CMOS chip in the HV series of HDV camcorders (HV10/20/30) is larger, with a slightly lower pixel count (1/2.7 and 2.96 megapixels) than the HF series of AVCHD camcorders (1/3.2 and 3.31 megapixels).
Yes. That and the body color are the only differences.
Old January 7th, 2008, 11:11 AM   #20
One cannot logically compare bit rates between HDV and AVCHD as they are two different formats.
Two different codecs, isn't it? I keep hearing that AVCHD doesn't handle motion well, despite offering "Full HD Lens to Screen" resolution.
Actually, I'm trying to get OUT of the "numbers trap." But it's very difficult to discern real-world performance from the various numbers which the marketers sling out. As you pointed out, codec efficiency can be a "choke point" which may nullify other features such as pixel count, imager size, and even bit rate.
Mike Brown is offline   Reply With Quote
Old January 7th, 2008, 11:15 AM   #21
I wonder how Final Cut Pro handles AVCHD - I've been put off AVCHD because of people saying it is difficult to edit with NLEs
Old January 7th, 2008, 11:25 AM   #22
DVInfo is the cure for the numbers trap. You get honest information from the pros here and you can decide for yourself.
As far as figureing out new products like this you really have to wait for reports from owners.
Clips | Stills
Old January 7th, 2008, 12:01 PM   #23
Where's that manual focus dial? I wish these guys had a focus ring the lens looks like it protrudes enough to have one.
Evan C. King is offline   Reply With Quote
Old January 7th, 2008, 12:08 PM   #24
FCP6 takes in AVCHD as AIC or ProRes422.
Kaku Ito is offline   Reply With Quote
Old January 7th, 2008, 12:13 PM   #25
Sorry to hijack with another question
Is AVCHD 4:2:2?
Would ProRes422 give me a much bigger file size than AVCHD?
Old January 7th, 2008, 12:15 PM   #26
Probably have to use the joystick for the manual focus.
Is AVCHD 4:2:2?
4:2:0 isn't it?
Clips | Stills
Old January 7th, 2008, 12:15 PM   #27
Hey Chris:
Have you actually seen one of these yet ?
Question I have from standpoint of budget indie shooter:
1. Mic input: Standard Mini Jack ?
2. Is there a separate Head phone monitoring capability not tied to the AV jack and menu switching as required by HV20 ?
3. Auto Focus: IAF and Standard ?
4. How is manual focus achieved.
5. AVCHD: I will check this out at Cineform thread, but have we gotten pulldown and conversion lined out in Cineform yet.
Chris J. Barcellos
Old January 7th, 2008, 12:16 PM   #28
Just had a thought -
It says the HF10s lens filter size is 37mm where as the hv20/30 is 43mm
Does this mean it uses a smaller lens? Would this degrade quality at all?
Old January 7th, 2008, 12:19 PM   #29
It could be the same lens, just with a different filter threads.
Clips | Stills
Old January 7th, 2008, 12:25 PM   #30
Slow Motion Feature?
These new cams look great - except for the lack of a slow motion setting. Did I miss this in the fine print?
Zack Andrews is offline   Reply
