#16 | |
1. You need the windscreen to protect the microphone from the water. The SoundPro SP-SPSM1 has built-in windscreens which would probably do the trick. 2. The smaller mikes don't have a built-in cable. you'd need an extension cable and the point where the plug goes into the jack would be a vulnerable leak point. Perhaps you can seal it with silicone or rubberized tape. |
#17 |
Travel Video with the HV20
I went back and looked at the manual. It says that any microphone that is plugged into the mic input must have its own power supply. So far, none of the microphones that we've talked about have that characteristic.
Wow, this is turning out to be more complicated than I thought! Judy |
#18 | |
#19 | |
So, when the HV20 manual says that the microphone has to have its own power, it still will work? These microphones don't seem to have batteries or another power source. Judy |
#20 | |
#21 |
I was thinking of adding the Reactive MT-1 microphone stand, which comes with a 6' extension cable to attach to the camcorder. I figured I could use the tripod with its flexible legs to attach to an article of clothing (sticking out of a pocket, for example) along with the SoundPro SP-SPSM1 stereo microphone. It would also allow me to use the microphone 6' from the camcorder, which might come in handy some other time.
How do you think that would work? Judy Last edited by Judith Mazza; December 20th, 2007 at 06:32 PM. Reason: spelling |
#22 |
I suppose that would work. It's really a matter of personal preference. I do two kinds of travel videos -- for one kind, I use a tripod, carefully compose shots, choose filters and lenses carefully, etc. For the other kind, it's essentially "run and gun," walking around shooting what interests me. For the latter kind, I find it's best if I'm as unencumbered as possible. I like using the lapel mike in those situations (when the camera is under a cape) because it's easy to clip it to the outside of the cape, tuck up the wire and then forget that it's there. Carrying something in my pocket that's attached to the camera just adds clutter as well as a cable that can snag on something. Also, when it's raining and I'm using a cape, I'll attach a collapsed monopod to the tripod screw on the camera. This gives me a handle with which to hold the camera, and also lets me do quickie boom shots -- it's particularly useful for getting above the heads of the crowd. In that instance, I particularly wouldn't want the microphone anywhere but on the rain cape.
However, it all depends on how you shoot. |
#23 |
Hi Paul,
That makes a lot of sense. I hadn't thought about using a collapsed monopod in that way. I always carry a Joby GorillaPod with me, and I just ordered a spare quick release to put on the HV20. That's an excellent application. You are right about the clip attachment and the cape. I assume they must have one that would work with that microphone... Judy |
#24 |
I like the Adorama Monopod. It's the lightest and quickest to setup and take down that I've found. I use a small tilt-and-pan head on it, not for tilting and panning (that takes a proper fluid video head) but to lock it into whatever position I need.
As for the clip, I suspect any would work, even a standard stationery bulldog clip. |
#25 |
I was thinking that the rain cape might also be helpful in a dusty windy environment. Some of the time we may not have rain, but it may be dusty (desert conditions). What would you think about that?
So, just to summarize (I do appreciate your patience with me on this), the items to purchase would be the rain cape, the single point stereo microphone, and an extension cable. The veritable "fly in the ointment" is the connection between the cable and the microphone...making that less vulnerable to weather conditions. Would you agree? Judy |
#26 | |
So, just to summarize (I do appreciate your patience with me on this), the items to purchase would be the rain cape, the single point stereo microphone, and an extension cable. The veritable "fly in the ointment" is the connection between the cable and the microphone...making that less vulnerable to weather conditions. Would you agree? Judy[/QUOTE]I agree -- you've got it. :) |
#27 |
Judy, as a follow-up on the Vivanco mike, you can hear it in this video (http://vimeo.com/453481). The Chinese music which covers the title was recorded with the Vivanco and a Panasonic MD recorder at a live performance in Lijiang under less-than-optimum conditions (noisy audience, poor acoustics in the hall, recording position located off to the side instead of centered, etc.). It will, however, give you an idea of what this little stereo lapel mike can do. The video is also shot with my HV20 (actually some of the first footage I shot with it).
#28 |
Wow, that is great! I wish it was available here in the States.
Hopefully the one I bought will do an ok job also. I received the raincape today. It's nice and compact. I haven't had time to install it, but it looks sturdy but compact. Judy |
#29 |
Please let me know how it works out. It's probably my next purchase for the HV20.
