NLE recognize 25p??? at DVinfo.net
Old November 15th, 2007, 01:28 PM   #1
Hi,
how to recognize video, made by HV20 25p, in Vegas?
Thanks in advance
Slobodan Pazin is offline   Reply With Quote
Old November 15th, 2007, 02:32 PM   #2
It should automatically recognize it and play it back. If not, then the format the video was saved in is not compatible with Vegas.
Eugenia Loli-Queru is offline   Reply With Quote
Old November 15th, 2007, 02:57 PM   #3
Hi,
maybe I ask in wrong way, when I open .m2t( recorded video 50i or 25p) in Vegas, properties of the files show "field order=upper field first" , I expected
for 25p to show "field order=none(progressive scan)" or I have wrong.
Old November 15th, 2007, 03:40 PM   #4
If it was recorded as 50i, then it's correctly showing up as "upper field first". It should be progressive only if you are 100% sure that something was shot as 25p.
Old November 15th, 2007, 04:44 PM   #5
Hi,
in the menu hd standard I set it HDV(PF25), does it mean that I shoot
in 25p?
Old November 15th, 2007, 06:28 PM   #6
I don't have a PAL version, but I think so, yes.
Old November 15th, 2007, 06:48 PM   #7
Originally Posted by Slobodan Pazin View Post
Hi, in the menu hd standard I set it HDV(PF25), does it mean that I shoot in 25p? Thanks
The camera samples 25 full frames per second, slices frames in half and writes out the frames as 50i fields. This process is called "2:2 pulldown". The difference from normal 50i is that there is no temporal shift between fields of one frame, therefore frames can be fully reconstructed by either a TV set if you watch from the camera directly on TV, or by an NLE. The HV20 is known to not flag video as pulled down progressive, therefore for an NLE it appears like a regular 50i. I don't have Vegas so I cannot advise you whether you can just set video type as 25p, or you need to process it with another utility.
Michael Jouravlev is offline   Reply With Quote
Old November 16th, 2007, 05:13 AM   #8
It just means how it was encoded. It doesn't matter, 50i where both fields are the same is basically 25p.
Mikko Lopponen is offline   Reply With Quote
Old November 16th, 2007, 09:20 AM   #9
Hi,
thank you all. I learned something from your replies but obviously I ask wrong question (maybe my English is not on the level).
For example, I shoot video in 25p before 1 month and didn't captured it right away after the shoot and didn't marked anywhere that I shoot it in 25p.
I want to capture it today but in the mean time I forgot was it shoot in 25p or
50i, how can Vegas show me is it 25p or 50i
Old November 16th, 2007, 10:04 AM   #10
For example, I shoot video in 25p before 1 month and didn't captured it right away after the shoot and didn't marked anywhere that I shoot it in 25p. I want to capture it today but in the mean time I forgot was it shoot in 25p or 50i, how can Vegas show me is it 25p or 50i
AFAIK, there is no way to do this because the HV20 does not flag video as 25p or native 50i. So you have to experiment.
Old November 17th, 2007, 02:47 AM   #11
Hi,
thank you again, I will try to mark video shooted in 25p.
