HV20 settings to match xh-a1 Vivid RGB at DVinfo.net
Old November 9th, 2007, 08:06 PM   #1
I just got my HV20 as a deck for my XH-A1s and thought it would be nice to be able to use as a backup camera/insert shot camera. I use the Vivid RBG preset primarily and was wondering if anyone had some tips on how to mimic that in the HV20
Ryan Szulczewski is offline   Reply With Quote
Old November 13th, 2007, 01:31 PM   #2
well I would also eb interested in finding this out.
I have read that the best match for these two cameras are
cp8 on the A1 +
cinemode and neutral on the HV20
I have notice a little more of both saturation and contrast in the hv20 on these settings and the A1's footage is a little flat.
Leaving the HV20 in those settings, the vivid rgb is too punchy for a match. I have recently dropped the vivid rgb back to 15 on sat instead of 25 and personally I find it suits peoples skintones a lot better and is close to the saturation of of the hv20.
I pushed the brightness of the hv20 +1
Maybe Im as far out as a lighthouse because I havent shot a job with these settings yet. Ill know more soon.
If anyone can improve on what I am suggesting here it would be appreciated.
Ger Griffin is offline   Reply With Quote
Old November 13th, 2007, 02:30 PM   #3
I typically shoot at 30f because most of my deliverables are standard def DVDs. Cinemode on the hv20 is 24fps isn't it?
Old November 13th, 2007, 02:41 PM   #4
No. Cinemode is a seperate setting from 24p. You can use it with or without 24p.
Ian G. Thompson is offline   Reply With Quote
Old November 13th, 2007, 02:42 PM   #5
well alrighty then. RTFM I should
Old November 19th, 2008, 01:01 AM   #6
but the Hv20 does not do 30fp if im not mistaken.
Arif Syed is offline   Reply
