Thread Tools
Search this Thread
#16 |
Paul:
Is this a snap taken in the still camera mode, or a frame grab, or what ? It doesn't look like it is in the right aspect ratio to be 16:9 from video.
Chris J. Barcellos |
#17 | |
#18 | |
Ooops -- just looked at it again. I may have pulled it into a Premiere Pro project with the wrong settings. I'll have to look again. Okay, I looked -- The frame export was correct, but the pixel aspect ratio in Photoshop was wrong. |
#19 |
I was considering the V1U, but the HV20's price and feature set were enough value for me. If you do get an FX7, please share your findings on this thread, and if you can visit the same location as you did with the HV20, that'd be great too.
I've shot extensively with the V1U's older brother/cousin the Z1U and, in my opinion, the Z1U can't hold it's own against the HV20 in terms of image quality/resolution/lack of noise. My personal thoughts were (before the HV20 was announced) if I were going for a larger cam, I'd have gone for the Canon XH-G1 or Sony V1U (which has a much better image processor than the Z1U). Best of luck.
Mac + Canon HV20 |
#20 | |
I'm looking at that screencapture with my 24" Eizo and it looks great. Ofcourse there are compression artifacts if you zoom in 300%, it is hdv anyway. Absolutely astonishing that an image as beautiful as this doesn't cut it for you in a consumer camera. There has to be something wrong with your Toshiba. I know that some settings in lcd-monitors can increase grain and encoding effects so atleast check your brightness levels etc. |
#21 | ||||||
Next, Bayer-filters are used only on 1-CCD machines -- A Bayer-filter is a grid of primary color filters that allow a single sensor to reproduce colors. Obviously, there is no need for a Bayer-filter on a 3-ccd machine. Because the Bayer-filter is a grid, it can introduce high-frequency artifacts. I have an old TRV-20 that does this (if you like, I can post frame grabs that demonstrate this) and this was precisely the reason I moved to my VX2000, which is a 3-ccd machine and has virtually no perceptible artifacts. Quote:
#22 |
I wonder if CMOS versus CCD has something to do with your complaint? I'm much less knowlegeable than you are about video, but I have read many posts about artifacts that seem to come into play on CMOS cameras that do not on CCD's. Especially when it comes to horizontal motion. It's a given to me that you absolutely must pan as slow as possible with CMOS.
#23 | |
#24 | ||
What do you mean even by "you're completely wrong". Completely wrong in what? DV-codec has basic jpeg-artifacts and they could be seen as high frequency crawling on certain edges. What is wrong in that statement may I ask? Quote:
You have to be talking about mpeg-artifacts and if so an XH-A1 or the V1 will DEFINITELY not save you. They have your basic mpeg-artifacts just like in those screencaps. |
#25 |
#26 |
#27 | |||||
Yes, I do. Mpeg is not, "basically a jpeg codec such as dv." Mpeg compresses by identifying a reference frame and then compressing subsequent frames based on the delta between the reference frames and the frames that follow. DV-25 (and DV-50) only compress within in each frame. The temporal compression of mpeg is what introduces the motion artifacts. Because DV-25 does not use temporal compression, it is not susceptible to this particular form of digital artifacts.
#28 |
#29 | |
That's it, I'm gonna take some screencaptures from the HV20 and the Sony hc1 (that has the same image quality as the sony a1u) and set you straight. These cameras give an image quality that for example put the dvx100 to shame and its 3 sensors. I find it very hard to believe your vx2000 could keep up. Having seen video from vx2000 a year ago I still remember it being severely inferior to the hc1 (except in low lighting). |
#30 |
Folks, if you mention Motion JPEG in a thread where MPEG is discussed, please point it out by saying "Motion JPEG" at least once... it's easy to confuse mpeg and mjpeg. And by all means, let's keep it friendly at all times, please.
By the way, single-chip RGB can be nearly as good, equal to, or even sometimes better than three-chip color accuracy depending on certain particulars... in short, single-chip RGB is in the same ball-park as three-chip. |
